Outdoor J Box Install For Flood Light - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By BIG Johnson
  • 1 Post By DeeEyeWhy
Old 04-26-2017, 12:12 PM   #1
Rewards Points: 194
Outdoor J box install for flood light
Hey guys quick question,
Bought an outdoor (grey hard plastic almost rubber ) J box from HD to install a new flood light line. Should the box be recessed in the wall or can it sit on the wall screwed mounted in with the rubber waterproof gasket?
I ask because I have seen it done both ways in different videos.
DeeEyeWhy is offline   Reply With Quote
Old 04-26-2017, 02:55 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,466
Re: Outdoor J box install for flood light
If it is gasketed, it is usually okay for exterior use.
Old 04-26-2017, 05:42 PM   #3
Rewards Points: 898
Post a link to the specific box.
Jim Port likes this.
BIG Johnson is offline   Reply With Quote
Old 04-27-2017, 09:33 AM   #4
Rewards Points: 902
can be on the surface if its an outdoor box,
after installation i normally silicone around the top and sides of the box but not the bottom, i leave the bottom as is in case any water or moisture gets in it has a way to leak out
anyacolo is online now   Reply With Quote
Old 04-28-2017, 11:12 PM   #5
Rewards Points: 194
hey guys, sorry i didnt realize anyone responded.
here is the link to the box I bought:
http://www.homedepot.com/p/4-in-Roun...50GY/202284547
Old 04-29-2017, 12:17 PM   #6
J. V.'s Avatar
Rewards Points: 582
That box is surface mount only. Just what the doctor ordered. They make metal ones as well.
Make sure you use the threaded plugs (should be included with the box) in each hole that's not being used.
There is no need for any sealant unless you are OCD.
If it worked before you worked on it. You did something wrong.
Old 04-29-2017, 12:52 PM   #7
Rewards Points: 194
Thank you much. I will probably caulk just in case because as you guessed it I am OCD ?
J. V. likes this.
Old 04-30-2017, 12:36 PM   #8
J. V.'s Avatar
Rewards Points: 582
I'm the same way. I used thread tape on mine when I wired my gazebo here at my house.
Old 04-30-2017, 01:46 PM   #9
Rewards Points: 194
I didn't even think about using pipe tape on the threads, good call!
J. V. likes this.
Vanity light install help needed hoyt79 Electrical 4 02-28-2014 04:57 PM
Photocell garage/porch light install problem kunzweb Electrical 17 07-12-2012 07:23 PM
How do i install a second light...? Giuseppe Electrical 9 06-18-2012 05:26 AM
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 08:08 AM
