Outdoor Conduit Vertically On Siding? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2016, 10:24 AM   #1
Rewards Points: 76
Outdoor Conduit Vertically on Siding?
I have an outdoor light on the porch mounted on a box where the fascia meets the exterior wall (vinyl siding). I wanted to run some conduit 6 feet or so straight down to install an outdoor GFCI a few feet above the ground directly below this light fixture (I have grounded cable to the outdoor box, and don't mind the outlet being switched).
What is the proper way (if there is one), to run outdoor conduit vertically down this siding? Not sure how to handle all the 'bumps,' for lack of a better term.
Thanks!
jerkbag is offline   Reply With Quote
Old 06-24-2016, 12:46 PM   #2
J. V.'s Avatar
Rewards Points: 348
Re: Outdoor Conduit Vertically on Siding?
These are made for metal conduit and are metal themselves. But if you don't mind an industrial look. These will do the job.
Old 06-25-2016, 07:50 PM   #3
Rewards Points: 36
Those or any type of stand off should work!
cjp2003 is offline   Reply With Quote
Patio Cover and vinyl siding? r_halleman Building & Construction 7 03-30-2013 12:55 PM
Siding right on studs? Davef_dci Carpentry 6 03-07-2013 05:31 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
