Opening New Coffee Shop - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 12:40 PM   #1
Question
Opening new coffee shop
Hi,
I'm in the process of having a space built out for a coffee shop. I need at least 200 amps to run the equipment. The current panel says 100A MAIN BREAKER, BUSSING 225A. VOLTS 208/120V.
My question is what does bussing 225A mean? Do I have enough amps?
Really appreciate any information. Thanks.
maxcat is offline   Reply With Quote
Old 08-04-2010, 01:20 PM   #2
Main breaker is 100a
Usually that is all you have
Unless possibly a split bus
Can you post a pic ?
Old 08-04-2010, 01:29 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
208/120 is 3 phase power
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-04-2010, 01:44 PM   #4
I attached a picture of the tag on the panel and a pic of what I think is a transformer.
Thanks.
Old 08-04-2010, 01:56 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 23,968
Definitely a three phase panel. You should be buying equipment rated for commercial 208 power. You may be disipointed in 240 equipment used on this system. It will be slightly lower power than normally espected.
Old 08-04-2010, 01:58 PM   #6
I was told I need at least 200amps, but it sounds like 3 phase should be sufficient to run commercial grade kitchen/coffee appliances?
Old 08-04-2010, 02:11 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Thanks.
where did you come up with the bussing 225A?
basically, you have a 100 amp panel. The other pic is a transformer and a disconnect. It may or may not be fused. Without peeking in it, no way to really tell.
So, if somebody told you you need at least a 200 amp service, you do not have enough power. Without knowing what size that transformer is, no way to tell you if it would power a 200 amp panel. Generally you do not put in a transformer that is oversized such as that. It costs more and nobody wants to spend money.
who told you you needed 200 amps?
Old 08-04-2010, 02:16 PM   #8
Super Moderator
joed's Avatar
Unless you tell us all the apliances and their ratings we can't answer your question. You need to do a demand load caculation. Fridges, coffee makers, dish washers, water heaters, air conditioners, frunaces, etc all need to factored into wether you have enough power or not.
Old 08-04-2010, 02:56 PM   #9
@nap
I got bussing 225 from the electrical drawings for the space. I tried attaching the drawing but it's too big.
Here's some transformer info I took from the plans:
NEW DRY TYPE TRANSFORMER, 30KVA 480V-120/208V, 3∅, 4W WITH (4)-2.5% FCBN TAPS, LOW SOUND LEVEL, CLASS H.
My coffee shop consultant said I need 200amps.
@joed, got it, thanks.
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Wiring shop need advice stqevo Electrical 14 09-03-2009 12:18 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Simple coffee shop sink ppark Plumbing 4 07-16-2009 11:31 AM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
