Oops, I'm Sure Everyone Has Done This At Least Once - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 06:50 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Oops, I'm sure everyone has done this at least once
Setting the multi meter to amps instead of volts when checking a receptacle.
Yeaah, I accidentally did that today, and well, I did confirm the receptacle worked, and it is the last one that meter will ever confirm to work.
Old 09-01-2009, 07:02 PM   #2
dSilanskas's Avatar
wow ha ha
dSilanskas is offline   Reply With Quote
Old 09-01-2009, 07:09 PM   #3
Rewards Points: 3,036
Setting the meter to ohms (continuity) will also result in frying if you measure with the power on.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 09-01-2009, 07:10 PM   #4
Old School
cabinetman's Avatar
Some multi-meters can read way over 100 amps. If you overloaded it, it may be fused which is an easy fix.
cabinetman is offline   Reply With Quote
Old 09-01-2009, 07:12 PM   #5
This won't happen with a "real" meter. They have protection built in.
220/221 is offline   Reply With Quote
Old 09-01-2009, 07:13 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Red, Welcome to the testing world
If there is no melted plastic,
magic smoke, or a nose wrinkling smell take the back off, and check the fuse.
http://en.wikipedia.org/wiki/Magic_smoke
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-01-2009, 07:51 PM   #7
Wire Chewer
Rewards Points: 528
Oh there WAS a fuse, but I could not find a replacement, so I had to do the unthinkable and... yeah. Knew it was bound to happen too. The solder sorta acted as a fuse, but was not fast enough.
If I buy a more expensive meter like a greenlee, will they use standard fuses? that was my problem with this one, it was non standard and it was impossible to get a replacement the first time I blew it. I had forgotten to swap to the 10amp terminal when testing amperage correctly when I had blewed the fuse. Oops.
Old 09-01-2009, 09:00 PM   #8
Multimeters use special fuses that are fast-acting and have the ability to interrupt very large currents without exploding. Many have both a low-current fuse connected to the voltage input and a high-current fuse connected to the 10A input. Some Fluke meters use these Buss fuses. This kind of fuse will probably cost around $8-10 apiece in single quantity and can be bought from an electronics distributor--try Digikey or Mouser if you don't have a local supplier.
Accidents such as the one you experienced are going to happen from time to time. That's why you want to make sure you're using a meter with at least a CAT III 600V rating, with the proper fuses installed. Search Youtube for "multimeter explosion" if you want to see what can happen when a bottom-of-the-barrel meter is used incorrectly.
Matsukaze is offline   Reply With Quote
Deck repair, oops replace, oops new patio door thread drtbk4ever Project Showcase 19 09-16-2009 09:20 PM
Non-IC rated lighting in Insulated cieling. OOPS! MyMonkey Electrical 7 02-22-2008 09:46 PM
oops? LipCa Electrical 16 10-28-2007 09:31 AM
Oops! greenhorn Painting 3 06-19-2007 07:54 PM
