Oops I Think? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 06:27 AM   #1
oops I think?
Used some green wire nuts to pigtail the grounds...but needed to add a length of ground. I inserted the piece through the little hole and twisted tight....everything secure at the time...but I am now not sure if this was an acceptable use of this type of wire nut.
So, the question is....should I re-do these connections and use a standard pigtail procedure?
Oxymoron is offline   Reply With Quote
Old 01-28-2010, 06:29 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
That is what the greenies are for. Just make sure you have a good twisted connection.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Deck repair, oops replace, oops new patio door thread drtbk4ever Project Showcase 19 09-16-2009 09:20 PM
Oops, I'm sure everyone has done this at least once Red Squirrel Electrical 7 09-01-2009 09:00 PM
Oops! greenhorn Painting 3 06-19-2007 07:54 PM
Big oops. Fixable? Solo4357 Remodeling 2 02-15-2007 08:19 PM
