One More Box Extender Question ... - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 07:53 PM   #1
One more box extender question ...
Can I extend my metal outlet boxes using the pvc extenders? Outlet location in kitchen,will be adding marble tile backsplash.Thanks.
nel262 is offline   Reply With Quote
Old 12-07-2010, 09:05 PM   #2
Licensed electrician
Rewards Points: 3,660
You will need to run a grounding conductor out to the ground screw on the devices to assure thay are properly grounded.
Old 12-08-2010, 09:01 AM   #3
My wireing is with BX cable.Isn't the wireing/outlet considered grounded with the bx attached to the box?Do I still need another grounding wire?Wouldn't the longer screw needed to attach the extender to the metal box complete the ground that you mention?Thanks
Old 12-08-2010, 10:29 AM   #4
Just call me Andrew
Rewards Points: 1,032
First off, not all flexible metallic conduit is listed to use as the ground. It has to have a metal strip running inside it for that.
That being said, I don't think the screw holding the outlet to the box is enough to properly ground the outlet. You should run a ground wire and attach it to the box.
Andrew
secutanudu is offline   Reply With Quote
Old 12-08-2010, 11:56 AM   #5
The bx that was installed has this metal strip in it.But I will add the ground that is required.Thanks
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
