One Box, 3x 14/3 Wires, 2x 3way Switches Controlling Each Their Own Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2015, 09:00 PM   #1
One box, 3x 14/3 wires, 2x 3way switches controlling each their own light
So I've been doing most of the replacement for the light switches without any issues and now I'm in the process of replacing the last one and I think I acted a little carelessly as I untied the whole configuration and now I'm lost...
So I have this one electrical box with 3 sets of wires (14/3), each has a white/black/red/ground lead. As per the picture only #2 is live the other two have no current going through them (at least according to my indicator).
cable set #1 is suppose to control the ceiling fan in the living room along with a switch one floor above.
cable set #3 is suppose to control the light in the kitchen along with a switch in the hallway.
To resume, one electrical box, 2x three-way switches for two difference lights, 3 sets of 14/3 cable, only one live.
I need to hook up two switches (one being a dimmer).
Attached is a picture of the electrical box
edit: In case someone misses it in the title, I'm trying to install two 3-way switches
One box, 3x 14/3 wires, 2x 3way switches controlling each their own light-untitled.jpg
bender248 is offline   Reply With Quote
Old 10-17-2015, 10:33 PM   #2
Rewards Points: 1,428
Which one of the conductors of the cable in the middle is live?
Last edited by poiihy; 10-17-2015 at 10:57 PM. Reason: deleted quote to save space
poiihy is offline   Reply With Quote
Old 10-18-2015, 06:29 AM   #3
Well all I have is one of those pen shaped current detector, as far as I can tell it reacts with every strands on the middle 14/3. I could get something to tell me the voltage and see which strand has the positive voltage (I think that's what you mean?)
Old 10-18-2015, 05:37 PM   #4
Ok so I'll try to provide more details
In the middle set of cables:
B-W : 125v
R-W : 95v
R-B : 3.5v
All other cable combinations end up at 0v
Old 10-19-2015, 03:52 PM   #5
B-W : 125v
R-W : 95v
R-B : 3.5v
Ok, so the black wire of the cable in the center is the line in power. The other readings you are getting are phantom voltage.
Old 10-19-2015, 08:36 PM   #6
Rewards Points: 516
This is a bit tricky to troubleshoot over the Internet. You might need an ohmeter. To be honest, the 14/3 with the line to neutral 120 throws me off. I'd take it one wire at a time.
I'd start by figuring out which wires are travelers. You'll need to take apart the threeways at the other end and and remove the two wires on the brass screws. Put them under a nut and use an ohmeter to find the set of wires at your mystery box that has near infinite resistance. Once you do that to both three ways you'll have three wires, one from each cable, left to ID.
Arrow3030 is offline   Reply With Quote
The Following User Says Thank You to Arrow3030 For This Useful Post:
bender248 (10-20-2015)
Old 10-19-2015, 08:43 PM   #7
Rewards Points: 516
A tip for next time. I twist sets of travelers together, cork screw switch legs and put a wire nut on line voltage wires whenever I install or take apart switch boxes to make the finish work easier. I have had my hands on so many jobs lately that I use a label maker now too.
I worked with a guy who used a dab of nail polish to color code wires.
Old 10-19-2015, 10:41 PM   #8
Speaking of wrapping wires together, in our other house, whoever wired the house wrapped the hot conductor around the traveller wires of a 3-way switch, and did similar to other switches. Basically wrap one wire around others to bundle together. Kinda neat.
Old 10-20-2015, 06:01 PM   #9
Thanks for the help, electrical is one of those things that always threw me off. I have an electrician coming on Thursday to help solve this. Hopefully it`s going to be just a piece of cake for him. I capped the wires with marrets for now.
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 22 09-28-2019 09:54 PM
Add dusk/dawn light AFTER 2 on/off switches cbuddyw Electrical 7 11-19-2013 11:31 PM
Replacing multi-use light switches jimclark Electrical 4 08-30-2011 02:05 PM
Old light switch, only two wires? AustinTexas Electrical 5 07-23-2011 07:38 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
