One Baseboard Heating In Palleral Wiring Won't Heat Up - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 10:10 AM   #1
hohadcr's Avatar
Rewards Points: 450
one baseboard heating in palleral wiring won't heat up
Hi,
I have two baseboard heaters wired pallerally to one breaker. One of them are not warming up to hot hot while the other one works well.
I have two other baseboard heaters on another breaker that both only warm up but don't get really hot.
what can be wrong? maybe the thermometer?
Thanks in advance.
hohadcr is offline   Reply With Quote
Old 12-18-2009, 10:46 AM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
You have them wired incorrectly.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 12-18-2009, 10:52 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 24,052
Is t he one unit warming slightly but not hot? If so then you probably wired them in series instead of parallel.
What is the wattage of the two units?
Old 12-18-2009, 11:47 AM   #4
hohadcr's Avatar
Rewards Points: 450
they are both 1200W.
Both are connected in one juction box to the wire that goes to the breaker. How could I wired it wrong?
I reversed the ins and outs on the themometer? I did the wiring all according to the instruction, same themometers, same heaters and same instructions.
Old 12-18-2009, 04:16 PM   #5
Super Moderator
joed's Avatar
Then there is only one conclusion if it is wired properly. The heater is bad.
Hotwater baseboard heat sound like loose change ctrait HVAC 1 01-11-2009 09:42 AM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 04:04 AM
Electric Baseboard Heat Skydmark1 HVAC 9 10-14-2007 08:03 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 04:12 PM
