One 3-way Switch 2 Lamps - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2014, 10:51 AM   #1
Question
One 3-way switch 2 lamps
Is it possible to take a 3 way wall switch, on - off - on and connect two lamps?
humpty111 is offline   Reply With Quote
Old 08-16-2014, 03:30 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,904
We need more details about what you are wanting to do. It is possible to control two light with a three way setup.
A normal three way switch does not have a center off position so I am not sure what you are attempting to do.
Old 08-17-2014, 12:47 AM   #3
dmxtothemax's Avatar
Rewards Points: 7,850
YES !
dmxtothemax is offline   Reply With Quote
Old 08-17-2014, 01:21 AM   #4
jproffer's Avatar
Rewards Points: 452
Easy there, lol...
as long as you want one lamp to be on all the time, then yes. As joed said, there's no off position, so if you want to be able to turn them both off...ever, then no you can't (with a typical 3-way switch).
EDIT: Unless of course, you feed your 3-way with a single pole switch. Then that one would turn both off, and the 3-way would be sort of a selector switch.
I think..........I can picture the wiring, and I think that's how it could work.
jproffer is offline   Reply With Quote
Old 08-17-2014, 08:16 AM   #5
Rewards Points: 29
You can get a single pole double throw (SPDT) light switch that would work.
Sent from my iPhone using diychatroom.com
Ben25 is offline   Reply With Quote
Old 08-17-2014, 09:25 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,830
Really not sure of your objective........
But, while not standard stock at the big-box, you can get SP/DT co (single pole double throw center off) or SP/TT (single pole, triple throw and just not wire up the third throw)
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 08-17-2014, 10:45 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Not real sure what your wanting to do. A 3 way switch is used with another 3 way switch and allows for turning on and off lights from two different locations in your home or business. It has no actual 'off ' position.
What exactly is it your wanting to do ? You could purchase a 3 position switch with center 'off ' which would allow you to have one or the other light on or both off.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-17-2014, 11:25 AM   #8
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Anyone else consider someone making these questions up? Ambiguous. Lacking detail.
clw1963 is offline   Reply With Quote
Old 08-17-2014, 11:44 AM   #9
Rob
Robpo's Avatar
Rewards Points: 826
Yea. Was considering making one up myself.
Robpo is offline   Reply With Quote
Old 08-17-2014, 04:36 PM   #10
Why won't it work ?
Old 08-17-2014, 04:58 PM   #11
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Originally Posted by dmxtothemax View Post
Why won't it work ?
Not saying it won't. Commenting on the type of questions appearing on the forum in general. This weekend. Maybe it's me and I'm newer. Just seem to lack more detail than norm.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Diagram for 3 way ceiling fan light switch Aurora65 Electrical 22 11-27-2012 09:11 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
