Oldman56 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 08:36 PM   #1
Question
oldman56
Where is the best place to order 2awg 240v 1-phase wire, about 1,100 ft.
oldman56 is offline   Reply With Quote
Old 06-21-2009, 08:39 PM   #2
dSilanskas's Avatar
You can get that at Home Depot and Lowes, or any electrical store.
dSilanskas is offline   Reply With Quote
Old 06-21-2009, 08:49 PM   #3
I've search lowes and home depot websites with no luck and also searched the web.
Old 06-21-2009, 08:59 PM   #4
dSilanskas's Avatar
If your looking for single conductors that you can put in conduit than all you need is #2 THHN but its the amperage you need to know.
Old 06-21-2009, 09:20 PM   #5
http://www.wesbellwireandcable.com/Electricalwire.html
Plumbvoltage is offline   Reply With Quote
Old 06-22-2009, 09:58 AM   #6
J. V.'s Avatar
Rewards Points: 362
What is this wire for? If you cannot find it on the web you are not using the correct key words for what you are looking for.
Call your local electrical supply they might help. Or go to HD or Lowes and ask them. When you are ready to buy (know what you need), get prices from both.
Old 06-22-2009, 10:05 AM   #7
Household Handyman
Rewards Points: 1,412
When I read your post, what I get out of it is this: This man wants one piece of wire, that is #2 AWG, of unknown sheathing, has the capability to carry 240 volts of unknown amperage, and needs to be 1,100 feet long. Being as you did not state which color there is one more piece of this puzzle. Please share with us more details and you will receive a better answer. Thanks, David
Old 06-22-2009, 03:15 PM   #8
Question
new question
I need to run an electrical wire about 600 ft. from my home to my work shop. I have a 150 amp panel in my home and need 60 amps at the work shop. What size wire do I need, how deep does it need to be buried, I can't run it in conduit because the ground is not level, can I run the wire in pvc and if so what size sould I use? Thanks
