Old Zinsco Service Panel - No Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2018, 06:46 PM   #1
Rewards Points: 26
Old Zinsco Service Panel - No ground?
So I'm installing a mini split ac and while looking at my service panel I noticed no grounding wires on the neutral bar. I also don't notice any copper wire going to the neutral bar. Does this mean my panel has no grounding/neutral bar not bonded?
Also does anyone have any idea how to pop out knockouts from the inside of the panel? I had no luck with a hammer and flathead.
Help is appreciated
818han is offline   Reply With Quote
Old 08-24-2018, 07:42 PM   #2
Rewards Points: 18,032
Re: Old Zinsco Service Panel - No ground?
Google Zinsco recall.
Old 08-24-2018, 07:48 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 29,188
I don't see any ground wires in that panel anywhere. I do see a white cable that appears to be bolted to the chassis under the two red wires.
Old 08-24-2018, 08:30 PM   #4
Rewards Points: 26
Yeah I know about the recall. Interesting thing is, it seems my surrounding neighbors haven't replaced their panels yet either. Our homes were built in 1965. Nonetheless, I know it needs to be replaced but right now can't afford it. Replacing the panel is likely a project for next summer.
Old 08-24-2018, 08:34 PM   #5
Rewards Points: 26
Not bolted just seems to be a dirty old cap on it. I'm assuming although *usually* you can place neutrals and grounds on the neutral bus in main service panels this is not one of those cases?
If so, looks like my mini split air conditioning won't be grounded for a little while
Old 08-24-2018, 09:02 PM   #6
Licensed electrician
Rewards Points: 3,670
The label should show the location of the bond screw or strap.
Old 08-24-2018, 09:04 PM   #7
What is the wiring method used? Metallic cable would not have a grounding conductor from that era.
Old 08-24-2018, 09:14 PM   #8
Rewards Points: 26
Here is the label
Old 08-24-2018, 09:17 PM   #9
Rewards Points: 26
All wiring in the house seems to be mc cable. For the mini split air conditioner I am using UF-B in loctite conduit since it will be outdoors.
The only issue is grounding the condenser.
Old 08-24-2018, 09:51 PM   #10
Check for continuity from the neutral to the case.
Old 08-24-2018, 10:25 PM   #11
Maintenance / Locksmith
Rewards Points: 256
To get the knockouts out.............first turn the power off.
Drill a hole about 25% the size of the knockout centered. Screw in a long screw and/or bend it back with a punch. Wiggle a few times and it will break off.
When done and hands out of panel.......turn power back on.
georgemcq is offline   Reply With Quote
Old 08-24-2018, 11:49 PM   #12
Super Moderator
joed's Avatar
This is not a cap. It is lug, but I can't tell if it actually bolted to the panel.
Old 08-25-2018, 05:41 AM   #13
Rewards Points: 26
Good eyes! I'll check in the morning and send you an update.
Old 08-25-2018, 05:42 AM   #14
Rewards Points: 26
I'll do that in the morning and send an update!
Old 08-25-2018, 05:44 AM   #15
Rewards Points: 26
I tried this earlier but my bit wouldn't bite due to limited space and the angle
Main Service panel grounding question KirkJT Electrical 17 05-25-2016 04:35 PM
Wire 200A Subpanel that will become main panel NickWa Electrical 7 02-19-2015 02:55 PM
Need help installing new service and making old service a sub panel fightermage Electrical 9 09-26-2012 09:48 PM
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 09:39 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
