Old Work Box Won't Work - Drywall Not Strong Enough At Corners - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2015, 08:12 AM   #1
Rewards Points: 2,084
Grateful to know options. Blue Old Work Box with the rotating arms that grab the drywall when tightening them, won't work because they pull right through the drywall (one of them does anyway).
justplumducky is offline   Reply With Quote
Old 01-07-2015, 08:34 AM   #2
Rewards Points: 3,396
Try a Madison bar also.
ritelec is offline   Reply With Quote
The Following 2 Users Say Thank You to ritelec For This Useful Post:
COLDIRON (01-08-2015), justplumducky (01-07-2015)
Old 01-07-2015, 08:37 AM   #3
Little nutty but if you can install a piece of thin wood or shim across where the wing is breaking thru so it goes against the shim and. It the sheatrock
The Following User Says Thank You to ritelec For This Useful Post:
Old 01-07-2015, 09:13 AM   #4
*If your wall opening is next to a wall stud, you can screw the box to the stud.
MrElectricianTV is offline   Reply With Quote
The Following User Says Thank You to MrElectricianTV For This Useful Post:
Old 01-07-2015, 09:24 AM   #5
Rewards Points: 1,192
Arlington 1 box
bobelectric is offline   Reply With Quote
The Following 3 Users Say Thank You to bobelectric For This Useful Post:
b4bhomeowner (01-07-2015), justplumducky (01-07-2015), sgip2000 (01-07-2015)
Old 01-07-2015, 10:01 AM   #6
If it's for a receptacle, could you turn it into a 2 gang box (double duplex) ??
Just another suggestion..
Yes those boxes are tough sometimes...
Sometimes it helps to runn the threads before installing the box also with those boxes to help the thread along so your not playing games..
I might suggest an old work metal with madisons, but using the plastic your hole is probably too big..
Try the first thought, adding a madison.
OK.. besides cutting a large square of new sheatrock for that area....
Leave the box for now, with the wing back.. fill the hole with a mix of spackle and plaster paris (maybe spackle mesh or paper too... maybe..).. let dry ( shouldn't take too long because of the plaster paris ).. retighten wing... NOT TOO TIGHT .
about it..
ben's plumbing (01-07-2015), justplumducky (01-07-2015)
Old 01-07-2015, 11:23 AM   #7
Oso954's Avatar
Rewards Points: 1,660
If you are up against the stud, try the arlington F101.
If you are supporting just on dry wall, try the 7010-8. Different sellers refer to it by different names, Thomas and Betts, Carlon, Union.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 01-07-2015, 07:19 PM   #8
*That sounds like a good idea. Maybe a 2" wide strip of quarter inch thick Luan glued to the backside of the drywall would suffice.
Old 01-07-2015, 07:31 PM   #9
Rewards Points: 582
did you over tighten it...had a helper doing that all the time....
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 01-07-2015, 07:52 PM   #10
Well, could be... I've installed plenty of these boxes in drywall (but apparently, not plenty enough), but the screws were really tight on this one, at least the one that came through the drywall. Tight enough that I didn't notice what was happening. I did take it back out, and run the screws through a bit, trying to loosen them up, but by that time... too late. Lesson learned, yepper.
Thanks so much for all the replies. Not sure what I'll do yet, but it is drywall only both sides. Not next to a stud. Wanna go look in the store at these different suggestions. No hurry on this job. Maybe this weekend.
The Following User Says Thank You to justplumducky For This Useful Post:
Old 01-07-2015, 07:55 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
Get a handful of paint paddles. Cut a piece about 6" long, glue in place with Power Grab.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Old 01-07-2015, 07:57 PM   #12
Rewards Points: 582
in your defense.. yep.. got a few with really tight screws ....makes it hard to judge how tight to make it...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 01-07-2015, 08:00 PM   #13
Like that idea too!
Old 01-07-2015, 08:01 PM   #14
Thank you Sir!
Old 01-07-2015, 08:53 PM   #15
Rewards Points: 6,652
If you are causing the bars to pull through the drywall, either it is really thin, the back has broken off of the drywall, just leaving paper, or you are over tightening the screws to cause the brackets to pull through.
You only have to snug the brackets up, until the box moves and that is it.
The Following User Says Thank You to gregzoll For This Useful Post:
justplumducky (01-08-2015)
Turning bullnose drywall corners into square ones ptulula Building & Construction 8 03-05-2014 09:37 AM
Looking to smooth out/fix drywall and fix corners surfndopamina Drywall & Plaster 11 01-17-2013 08:31 PM
25 lb box of drywall screws has strong smell mazey Building & Construction 0 02-08-2011 08:45 AM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 06:17 AM
How is a drywall screwgun suppose to work? KUIPORNG Remodeling 10 11-03-2006 11:19 AM
