Old Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 02:56 PM   #1
Old wiring
My kitchen light switch just blew out today. There was an actual flash from the side of the switch. The problem I'm having is that the wiring in my condo isn't very modern. I pulled the switch(after shutting the breaker off) and there is 1 purple wire that is stripped, but not cut and wraps around the top post. Then there is a yellow wire that is cut and goes to the bottom post...nothing else. I bought a single pole switch and really not sure what to do. Should I add a ground somehow?
Moparbird1970 is offline   Reply With Quote
Old 07-15-2010, 03:30 PM   #2
I figured it out.
Old 07-15-2010, 04:22 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 952
Originally Posted by Moparbird1970 View Post
I figured it out.
Glad you figured it out.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
