Old Light Switch Not Grounded - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2020, 05:30 PM   #1
Rewards Points: 22
I'm replacing an old light switch with a Lutron Wifi one. However, the old switch isn't grounded. There is a green wire attached but it is just capped. The new one does have a ground wire. Does that matter ?
andrewlowe3 is offline   Reply With Quote
Old 04-10-2020, 05:48 PM   #2
Rewards Points: 14
Re: Old Light Switch Not Grounded
Does your new switch require a neutral? If so, is there one tucked into the back of the box?
Switches do not require a ground to work, although some can use the ground in place of a neutral. If there is a ground wire in the box then wire nut it to the ground wire of the switch.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
andrewlowe3 (04-10-2020)
Old 04-10-2020, 06:02 PM   #3
Very Stable Genius
CodeMatters's Avatar
Rewards Points: 790
Agree with @daveb1 .
Also, last guy made joint poorly. Uninsulated wire should not extend outside
of wire nut.
CodeMatters is offline   Reply With Quote
The Following User Says Thank You to CodeMatters For This Useful Post:
Old 04-10-2020, 10:21 PM   #4
Missouri Bound's Avatar
Rewards Points: 4,212
Although it is now code, it wasn't for decades.
It is not uncommon to find only a switch leg in a switch box.
You will be fortunate to find one if you home is older.
Do you want it your way or the right way?
Missouri Bound is online now   Reply With Quote
