Old Barn--Bad Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 04:29 AM   #1
Enough is Enough
H. A. S.'s Avatar
old Barn--Bad Wiring
Took the cover off and this don't look right, or safe:.
It has 220 feed in from the bottom, all white wires, and a fourth white going to the ground post outside.
all this coming from my new outside 200 amp service/pole. The electrician said I can now run 100 A to this old barn, and run another 100 A line to my pole barn/metal shop.
I've always installed my own outlets and switches, but never hooked up a service entrance. Eventually, I'll have 150' of new cables run out to this new box.
Right now, I'm trying to figure out the best way to add more switches and outlets, to hold me over till I can afford the new underground cable installed. All the white wire you see, is 12 ga.
I'd appreciate any and all suggestions from the resident experts here!! Thanks in advance!
Harrison
old Barn--Bad Wiring-old-barn-electrical-box-2010-003.jpg   old Barn--Bad Wiring-old-barn-electrical-box-2010-005.jpg   old Barn--Bad Wiring-old-barn-electrical-box-2010-006.jpg
H. A. S. is offline   Reply With Quote
Old 10-25-2010, 12:32 PM   #2
Rewards Points: 320
An electrician did this? First things first, get a new electrician. Those conductors coming into the panel have to be enclosed in conduit or service entrance cable. There are no bushings/connectors in the knockouts for the incoming cables as well as the cables feeding the circuits on the right side of the panel either.
teamo is offline   Reply With Quote
Old 10-25-2010, 01:06 PM   #3
Rewards Points: 308
If you made your electrician pull a permit for stuff like this you would not have this non-compliant mess you have. I have seen bad work and I have seen bad work. This is extra bad IMO.
You do know why he mounted that panel where he did right? So he did not have to make any holes himself. Hack.
Make people pull permits!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Old 10-25-2010, 01:18 PM   #4
Rewards Points: 512
What the heck type of panel is this? If the service is coming in from the bottom, I don't see a main breaker, and I can't tell that this is an MLO. Where are the incoming service wires, i.e., black, black, white? What is supplying this panel, a 50A breaker from the house?
WOW
Old 10-25-2010, 02:19 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 23,964
Find the money and replace the entire setup with a new panel and the proper underground cable. Use a different electrician and get proper inspections.
Old 10-25-2010, 06:54 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Quite few of us are Electrician in this fourm so we know the answer.
That photo you show to us that is complety illegal set up I know it can be legit in old code but the way it set up it is NOT safe at all.
And I want to see the photo of what the so callled electrician did with your service box at the pole that what I am instering to see how bad it is.
A good Electrician will cover all base to make sure everything is legit.
If I was there I will make sure it is addressed during the service changeover that is my SOP and have the customer understand the safety I know it may cost more money upfront but once it done you have all the subpanels are legit with recenit code cycle.
Did that so called electrician pull the proper permits if so call the inspector and let them know you have issue going on.
Merci.
Marc
Old 10-28-2010, 08:37 PM   #7
Enough is Enough
H. A. S.'s Avatar
The electrician did the pole and new box, outside.
I thought with the dirt and ladybugs in there; would show that the box in the pics, is what was in the old barn. Getting ready to install a new box and breakers. Did you think I paid the electrician to install that box?
Do I win the contest for finding the most FU electrical box?
Old 10-29-2010, 01:01 AM   #8
Kinda close but few of us { Electricians } have see worst than that.
Merci,
Marc
Wiring for barn fjacky Electrical 4 10-06-2010 06:10 AM
How much power can i give my new barn? DonQ2010 Electrical 16 09-08-2010 09:23 AM
wiring new barn questions ugabulldog Electrical 13 12-24-2008 03:00 PM
Retro Barn Wiring Randell Tarin Electrical 12 02-22-2008 10:04 PM
Wiring a Pole Barn rocky Electrical 8 02-02-2006 06:34 PM
