OK To Use Wire In 14/3 As Neutral? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2015, 11:45 AM   #1
Rewards Points: 6
OK to use wire in 14/3 as Neutral?
I'm confident in my electrical abilities when it's something I've done before , but I've never done this.
Question:
Is it ok to change a 14/3 from Traveler/Traveler/Load/Ground to Traveler/Neutral/Ground/Capped?
See attached image for a visual description.
I'm installing Z-Wave switches replacing standard 3-way switches, and both need a neutral. The "master" switch has a neutral in the gang, but the "remote" gang just has a single 14/3 coming in. Fortunately, these switches don't work in the same way in that I only need a traveler, ground, and neutral at the remote location. The "master switch does all of the actual switching, the "remote" switch just "communicates" back.
Any issues with this setup? I can't think of any, but since I've never done, and couldn't find anything specific to this situation online, I thought I'd better check. Don't want to burn the house down and all that.
Thanks!
OK to use wire in 14/3 as Neutral?-wiring.jpg
zfwjs is offline   Reply With Quote
Old 10-20-2015, 11:51 AM   #2
Rewards Points: 3,438
Yes you may use or repurpose the white wire in a 14-3 as a neutral.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
Old 10-20-2015, 11:52 AM   #3
Rewards Points: 6
Excellent, thanks!
Old 10-20-2015, 02:11 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 32,018
Just be sure to use the white wire as the neutral.
Old 10-20-2015, 02:16 PM   #5
Rewards Points: 6
I did, and the red as the traveler.
Thanks!
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-20-2016 11:30 PM
Continuity between ground and neutral and old two wire wiring, input please..... Ralph III Electrical 46 05-22-2015 10:45 PM
Neutral wire tests hot but not full voltage retired guy 60 Electrical 6 03-10-2015 09:02 PM
How unsafe is this? Thurman Electrical 46 12-12-2014 10:53 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
