Off Center Vanity Light - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Unread 11-08-2019, 10:39 AM   #1
simeltzer's Avatar
Rewards Points: 54
So I have a pancake style j box for a vanity light in my half bath. It is a about 2” or so off center. It is stud mounted and just to the left of it is the vent pipe. My question is: Is there some sort of vanity lights that help in this situation with an off center mount? If not does anybody have any other suggestions? The photo shows the stud and pipe. Thanks in advance
Off Center Vanity Light-296865dc-1f72-4d48-b217-6cd42f958b03_1573227567134.jpeg
simeltzer is online now   Reply With Quote
Unread 11-08-2019, 11:16 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 112
Re: Off Center Vanity Light
Not sure what they call it... but there are light fixtures that are sort of a long stretched out box with bulbs often coming straight out.
Rather then mounting directly to your pancake box....they have a frame you mount to the wall and as such do not have to be centered over your Jbox.
You can center them relative to your sink, and the "box" will cover the span over your jbox, and your wiring just runs in the box.
I'd go to the bigboxers or maybe a lighting store and examine the different fixtures that will provide that offset and also cover your jbox.
MTN REMODEL LLC is online now   Reply With Quote
Unread 11-08-2019, 11:24 AM   #3
simeltzer's Avatar
Rewards Points: 54
Yeah that’s kinda what I was think I just didn’t know if they had a separate mounting plate like you said. I’ll have to go pick one up and see. Thanks for the quick response.
Unread 11-08-2019, 12:07 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 29,188
There should be room to mount the thin pancake box in front of the vent pipe. It can be mounted to the drywall if your fixture is not too heavy. The pancake box should fit behind many fixtures.
Unread 11-08-2019, 12:10 PM   #5
simeltzer's Avatar
Rewards Points: 54
Joed do they make a thin pancake remodel box?
Unread 11-08-2019, 01:01 PM   #6
Oso954's Avatar
Rewards Points: 42
I canít ever recall seeing a pancake remodel box. AFAIK, you always screw them to wood. You can either surface mount them over the drywall, or cut a hole to mount them directly to the wood.
I believe MTN was referring to a Hollywood light bar.
https://www.homedepot.com/p/Volume-L...-206935886-_-N
There are a few vanity lights that are made with a similar bar.
https://www.homedepot.com/p/Progress...3-20/205662515
MTN REMODEL LLC likes this.
Oso954 is offline   Reply With Quote
Unread 11-08-2019, 01:10 PM   #7
simeltzer's Avatar
Rewards Points: 54
Thanks oso954 I looked at some similar lights at HD. Looks like that will be my best option. Not The look I was going for but oh well
Unread 11-08-2019, 02:05 PM   #8
Rewards Points: 112
Yep...Thanks OSO...I knew it had a name.
Oso954 likes this.
Unread 11-08-2019, 04:07 PM   #9
Rewards Points: 8,174
The long multi-bulb vanity lights are typically a backplate and then the decorative chrome/brass cover snaps over-top. You could simply drill new box mounting holes into the backplate. See below example.
http://pdf.lowes.com/installationgui...86_install.pdf
Nealtw likes this.
SPS-1 is online now   Reply With Quote
Unread 11-08-2019, 04:10 PM   #10
simeltzer's Avatar
Rewards Points: 54
Awesome sps1. Thanks for the example
Unread 11-08-2019, 06:07 PM   #11
Master Electrician
Rewards Points: 5,116
Google “pancake remodel box”.
brric is online now   Reply With Quote
Unread 11-08-2019, 07:01 PM   #12
simeltzer's Avatar
Rewards Points: 54
Damn good job brric. Not sure why I never looked but they actually have the perfect one on amazon. Problem is that the wrong box I already in place so I’ll have to do some thinking. Thanks for the awesome tip. Not sure why I never looked
Unread Yesterday, 02:41 AM   #13
Rewards Points: 2,554
Then there are LED lights, such as https://www.amazon.com/Lithonia-Ligh...%2C391&sr=8-17
which may be suitable.
FrodoOne is offline   Reply With Quote
Unread Yesterday, 09:23 AM   #14
Rewards Points: 1,272
I know your pain. Had the same thing last summer with Pine paneling instead of drywall. The vanity chosen and countertop ended up being slightly bigger than expected causing a 1-2" off center of box. Wife commented on it so many times I had to fix it. 4 hours of work removing vanity then pine T&G in the middle of a wall, moving box 2" to left, then new T&G boards fitted with blind tongue and I was done. I was mumbling to myself the entire time.
Next time I think just rough out NM cable in the spot and mount box afterwards after all variables sorted out (i.e. vanity installed). Maybe put a backer 1x or 2x horizontally before finish (drywall or other) so you have something to mount the pancake box to later.
curiousB is online now   Reply With Quote
Unread Yesterday, 09:32 AM   #15
simeltzer's Avatar
Rewards Points: 54
Yeah that’s what shoulda been done here
