An Oddity - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 06:04 PM   #16
the Musigician
DangerMouse's Avatar
Originally Posted by StahlMaster View Post
If it is a suspended ceiling, I would check to see if the nails or hooks to tie the main rails of the ceiling grid are not driven into a wire. I would also check the rail around the Perimeter for the same thing.
D
Good idea! Certainly a possibility.
DM
Old 03-25-2010, 09:54 PM   #17
Master Electrician
thanks for the help people...got it figured out. Apparently my first assesment of the problem was the correct one after contacting the manufacturer and a few master electrician friends of mine. The system does infact have to be grounded to function properly due to the nature of the electronic ballasts. They need a ground reference point to work right. With all the harmonics in the ballasts and the fact that the grid is quite large it acts like a transformer almost in the sense that the ballasts are the primary and the grid is the secondary. It can induce a voltage right up to almost what the source voltage is but won't carry enough current to even register on an amp probe. So it would give you a bit of a jolt if conditions were right but no harm can be done. I'm sure i'll recieve a bunch of arguments from people out there about this but for those at trade if you really think about it and have an understanding of transformers then it makes perfect sense.
andrew79 is offline   Reply With Quote
Old 03-25-2010, 10:25 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
by theory, sure. Never seen it in real life. Maybe thats due to competent electricians installing EGC's where they are required.
Curious question:
down here in the states we cannot use NM above a grid ceiling other than in a 1,2, or multi family dwellings. Apparently you folks don't have a rule prohibiting the use? or is this a resi dwelling?
and do you know of anywhere on the net the Canadian Electrical Code is available online?
Old 03-25-2010, 10:33 PM   #19
Master Electrician
you are quite right on the nm thing....it's an old building. Romex was run in the walls and the original lights were surface. When the new grid was dropped in they ran from the nearest junction box which is in drywall. So the wire at the panel is a romex(where the ground was cut), but everything in the dropped ceiling is infact bx. Good call on that one though.
Old 03-25-2010, 10:57 PM   #20
nap
You talking to me?
nap's Avatar
but what about the CEC? We have enough Canadians here that I would really like to be able to refer to their code, if possible when trying to help those folks to.
In the alternative, if you cannot come up with a link, you are hereby drafted to remain a member of the forum so you can answer Canadian code questions.
Old 03-25-2010, 11:18 PM   #21
Master Electrician
i tried to find it and i couldn't....not suprising as it would cost them money on people not having to buy the books . I'll most likely stick around anyways...this place is like a black hole...i popped in to ask a question and now i find myself on it half the day. Just an FYI as i'm not sure how it works in other parts of the world but we have different code books for each province that have small variations on certain things that are in the CEC. We do use the CEC for trade school though.
