Number Of Can Lights On One Circut - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 07:56 PM   #1
Number of can lights on one circut
Looking for the max number of can lights on one 20 amp circut. Will probably be using 60 watt bulbs.
Dapaw is offline   Reply With Quote
Old 07-18-2010, 07:58 PM   #2
Electrician
Proby's Avatar
What's the maximum wattage rating of the high hat?
Why are you using a 20A circuit for lighting? #12 wire in those little junction boxes is a pain.
Proby is offline   Reply With Quote
Old 07-18-2010, 08:15 PM   #3
20a = 2400w /60w bulb = 40 bulbs
I never max out a lighting circuit, always leave some spare wattage
Canada has limits on the number of devices
Where are you located ?
Old 07-18-2010, 08:17 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If the fixtures are rated for 75 watt max, I would stay under 25 fixtures. If 60 watt rated fixtures, I would stay under 32 fixtures. Of course that is with no other loads on the circuit.
calculate the load with the max rating of the fixture. Never know if you might end up putting the max lamp size in the fixture.
the above numbers are figured with an 80% load on the circuit.
Old 07-18-2010, 08:19 PM   #5
Electrician
Proby's Avatar
I agree with nap, you are best to keep it at 80% and to go by the max wattage of the fixture, not the bulb you plan on using.
Old 07-18-2010, 08:21 PM   #6
I'm in Anchorage, AK
Old 07-18-2010, 08:41 PM   #7
Licensed electrician
Rewards Points: 3,658
Sizing the circuit is required to be on the maximum bulb rating of the fixture.
Old 07-18-2010, 10:18 PM   #8
" Euro " electrician
frenchelectrican's Avatar
It is my SOP is sized the circuit by maxuim wattage lumiaire rating so some luminaire I have ran into take much higher wattage so I have to go by the rating of them.
Merci.
Marc
Old 07-18-2010, 10:26 PM   #9
Do you know the code reference for that by chance ?
I've looked for it but unable to find it
The cans I buy have a max wattage of 150w (I think) depending upon bulb/trim
So I have always gone by my load
Old 07-18-2010, 10:30 PM   #10
Dave.,
I know it did mention in the NEC and for sure it do stated clear in French Electrical codes as well they will stated
"The luminaire circuit will be sized by maxuim wattage of the luminaires "
I am sure Jim can quote the excat number for NEC code on 2008 Editon for you.
Merci.
Marc
Old 07-18-2010, 10:46 PM   #11
nap
You talking to me?
nap's Avatar
can't say I've seen to many fixtures rated for 150 watt lamps either.
I can't cite code either but as I stated before, you need to use fixture rating. If not, you might end up putting in bigger lamps and if you calculated it on (you said yours are 13 watt, right?) and then put 150's in there, you can use less than 1/12 of the quantity on the same circuit. Could become a problem real easily.
Old 07-18-2010, 10:57 PM   #12
Electrician
Proby's Avatar
Are you agreeing or disagreeing with what I said? I'm not sure brother
220.14 (D) Luminaires. An outlet supplying luminaire(s) shall be calculated based on the maximum volt-ampere rating of the equipment and lamps for which the luminaire(s) is rated.
The Following User Says Thank You to Proby For This Useful Post:
Scuba_Dave (07-19-2010)
Old 07-19-2010, 04:27 AM   #13
I was agreeing with both yourself and NAP. Thanks for posting the correct Article.
Old 07-19-2010, 08:33 AM   #14
Thanks....I must have skipped past that section at least a dozen times
I actually do have my can ratings in a sprads sheet
I have 3 lighting circuits...one only has 1000w on it by the load calc
--this is the original lighting circuit in the house
--actual load w/CFLs/mix is 700w
But it has 2 old outlets in the dining room on the circuit
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
number of outlets and/or lights miller01 Electrical 12 10-13-2008 10:23 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
