No Power To Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2009, 12:47 PM   #1
no power to light switch
so I just recently purchased a new home. In the main bedroom there are no over head lights just receptacles. All these receptacles power.there is a light switch in the room that has no power going to it. I assumed that the switch was to connect these. so i went about my way to break on tab off the receptacle(the brass screw side). now only 1 half of my receptacle works and none of the others one. and besides this the outlets in the adjacent room no longer work. I'm so confused, any help is appreciated.
Greg
diople is offline   Reply With Quote
Old 05-16-2009, 12:56 PM   #2
Why did you break the tabs off? Power probably goes to one screw through the tab to the other screw where the wire for the next receptacle is connected. Before removing any tabs you have to know how it is wired. It is always a good idea to never make assumptions about wiring without tracing the wires to be sure.
hayewe farm is offline   Reply With Quote
Old 05-16-2009, 01:03 PM   #3
Electrical Contractor
kbsparky's Avatar
My best guesses are:
  • Only half of one outlet is switched. If you didn't check both the top and bottom of each outlet, you missed it.
  • You have essentially interrupted the circuit by breaking off the tab on an outlet. You will either have to install a jumper across the 2 terminal screws, or replace that outlet to restore power to the rest of the circuit.
Old 05-16-2009, 01:15 PM   #4
liscenced electrician
Rewards Points: 540
without being there its pretty hard to figure out why there is no power to the switch
but on the receptacles, as its already been stated, power was going into one screw on it, and out the other. since you broke the tab off, now power is going in one side, and stopping there. Not making it to the other screw
this is why i pigtail everything out, makes troubleshooting 10x easier
jimmy21 is offline   Reply With Quote
Old 05-16-2009, 01:29 PM   #5
i'm still in there trouble shooting, i'm using a tester ( two leads with a light) and i get power across any of the two white ones to black wire A , but nothing from either of the white wires to black wire B.
Old 05-16-2009, 01:34 PM   #6
The reason there is no power to the switch may be because it was installed with the idea of adding a ceiling fan later.
Old 05-16-2009, 02:40 PM   #7
Rewards Points: 2,350
Also, if you are using a light tester at the switch, it won't work unless you are measuring hot to ground. A tester of this sort won't work on a 2-wire switch loop.
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 03:33 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
A simple 2 light --1 switch question? [email protected] Electrical 7 11-05-2008 09:35 AM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 12:05 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 08:32 PM
