No Power To Bottom Of Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 09-03-2016, 08:09 AM   #1
Rewards Points: 32
No power to bottom of outlet
I had an electrician install a new panel with entirely separate electrical line from my main panel for some new outlets. I am only getting power to the top plug on the two counter top outlets and no power at all for a floor outlet where I plan to install a mini fridge. I've confirm all breakers are on and even switched the breakers off and turned back on but no change.
I don't think the outlets are bad since they are brand new but I notice he did break the tabs on both counter top outlets on both sides (half hot?). These plugs are not tied to any switch at all. Is there a reason why he would break the tabs in this situation? Is that to run the line to the bottom outlet off the counter top outlet? I've typically seen that done differently.
I've attached a picture of the wiring one top outlet to show what How the counter top outlet is wired.
I'd call my electrician but it's the start of Labor Day weekend and I won't get him until Tuesday.
csauveur is offline   Reply With Quote
Old 09-03-2016, 08:27 AM   #2
Licensed electrician
Rewards Points: 3,688
Re: No power to bottom of outlet
Where are you located?
Old 09-03-2016, 08:28 AM   #3
Rewards Points: 32
New Brunswick, Canada.
Old 09-03-2016, 09:17 AM   #4
Rewards Points: 18
With all due respect, are you sure there is not a switch somewhere? I see a red and a black connected to the hot side of that duplex. That tells me that one half of that duplex is always hot and the other half gets hot when a switch is turned on.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 09-03-2016, 09:33 AM   #5
Rewards Points: 32
Yeah, I've seen other posts where that has been the situation but I'm 100% sure there is no switch. I cut all the holes for the new outlets myself. He ran the line from the new panel to just the outlet holes I made.
Old 09-03-2016, 09:41 AM   #6
Rewards Points: 18
Are any of the outlets GFI's?
Old 09-03-2016, 09:43 AM   #7
Rewards Points: 18
Also, please explain what you mean by "new panel".
Old 09-03-2016, 09:45 AM   #8
Rewards Points: 32
Nope, no GFIs for either the two counter top outlets or the one at floor level.
Old 09-03-2016, 09:50 AM   #9
Rewards Points: 18
Are there any GFI breakers in your panel? I ask because here in the US code requires most countertop outlets to be gfi protected. Any ArcFault breakers?
Old 09-03-2016, 09:51 AM   #10
Rewards Points: 32
My main panel is in my garage. The electrician was concerned about load on the existing circuit in that room for what I was adding so he ran a line from my main panel to a sub-panel that was mounted in my furnace room on the other side of this wall.
I brought in added capacity than what I needed for this reno for potential future needs.
So he ran a line from the main panel to a sub-panel which has 4 breakers, one of which is feeding these new circuits.
(I may not be using all the right terminology there, but I hope that makes sense.)
Old 09-03-2016, 09:53 AM   #11
Rewards Points: 18
In rhe new subpanel, if you take off the cover, do you see any red wires connected to ant breaker?
Old 09-03-2016, 09:54 AM   #12
Rewards Points: 18
Typo *any not ant
Old 09-03-2016, 09:56 AM   #13
Rewards Points: 32
No, they look to be standard breakers both in the sub panel and the breaker that feeds that panel from my main garage panel.
Old 09-03-2016, 10:01 AM   #14
Rewards Points: 32
Yes, I do. Here is a pic of what the sub panel looks like. The left side are the plugs in question. The right side works fine.
Old 09-03-2016, 10:15 AM   #15
Rewards Points: 18
It looks to me like you have 6 breakers since those on the left appear to both be tandem breakers (2 breakers occupying one breaker slot). Note which half of your receptacles work (red or black) now. Then switch those tandem breakers in the panel and test your outlets again to see which half works (black or red).
Power Outlet and Light - Same switch ddzc Electrical 9 12-02-2014 09:06 AM
Switch for one power outlet ccdn Electrical 3 05-19-2014 10:29 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 07:27 PM
Only one outlet will power treadmill? archer75 Electrical 17 05-05-2009 01:20 AM
