No More Power. Can't Figure Out Why. - Electrical - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 1 Post By jmon
  • 2 Post By de-nagorg
  • 1 Post By mschmied89
  • 1 Post By dmxtothemax
  • 1 Post By Guap0_
  • 2 Post By Yodaman
Old 02-10-2019, 05:50 PM   #1
I've got two recessed lights in my master bath that are on the same circuit. I went to replace the fixture for one of them (shower light) with a flush mounted style that I like more for that location.
Since it was a recessed light to begin with, I used a converter kit to put in the flush mount, which is pretty straightforward work. I got everything installed but when I went to test the light I got nothing. No power to it or the other light on the circuit. I took it back apart, re-did the connections. I went around the house checking gfci, thinking one might need to be re-set, no luck there from all that I could find. Checked the breaker, nothing out of the ordinary from what I could tell. This circuit had just been working prior to me starting the work. I'm not sure if this helps but I've attached a link to the conversion kit, just to get a sense of how simple it is.
Any idea what might be going on here?
https://www.homedepot.com/p/Westingh...1100/204785596
mschmied89 is offline   Reply With Quote
Old 02-10-2019, 05:52 PM   #2
Cont...I even went so far as to hook back up the old lighting set up and still got nothing.
Old 02-10-2019, 05:56 PM   #3
Property Mgt/Maint
Rewards Points: 6,044
Re: No More Power. Can't Figure Out Why.
Go back to the breaker panel. Do you know which breaker specifically is feeding the lights. Toggle it back and forth. Some times they don't look like they have tripped, when actually they have.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 02-10-2019, 06:07 PM   #4
I don't. I should have killed the power at the breaker ( I know, I know) but I just did it at the switch for this. I would have known which breaker it's on if I did.
Old 02-10-2019, 06:24 PM   #5
Rewards Points: 1,974
Follow yodaman post above and look at main panel for a tripped breaker (As he mentioned, turn breakers all the way off then back on one at a time) or a tripped gfci somewhere. I know you checked this, but sometimes gfci's are in weird places and can cause this type of issue. Just saying.
Hope you get it figured out soon msch.
Yodaman likes this.
jmon is offline   Reply With Quote
Old 02-10-2019, 06:35 PM   #6
hkstroud's Avatar
Rewards Points: 5,572
Describe the wiring in the fixture. Tell us the number and kind of cables.
A wire is a wire, a cable is two or more wires in an outer covering. There are 2-wire cables (black white and ground) and 3-wire cables (black, white, red and ground).
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 02-10-2019, 06:41 PM   #7
I just tried the breaker again, no luck.
The fixture itself (old) is two wire, white and a black that goes to the ceramic bulb socket. The adapter and new fixture has the same set up. I can see the cable going to the box for the recessed light. Looks like two 14 awg romex in the box.
Old 02-10-2019, 06:42 PM   #8
It's 14/2 romex. It's not a three way switch.
Old 02-10-2019, 08:35 PM   #9
JUSTA MEMBER
Rewards Points: 2,542
A suggestion, did you reuse the old wire nuts from the old assembly?
If so, get new wire nuts, and try again.
I have been called to several DI Y ers goofs, to fix what they could not, all I needed was new wire nuts, and ten minutes.
Are they ever mad when the minimum charge of $75.00, hits them for 50 cents in parts, and ten minutes real work.
ED
Hidyi and Rough Rooster like this.
de-nagorg is online now   Reply With Quote
Old 02-10-2019, 08:56 PM   #10
Used new wire nuts
de-nagorg likes this.
Old 02-10-2019, 09:23 PM   #11
hkstroud's Avatar
Pull the switch. There you should find two 2-wire cables. The white wires should be wire nutted together. The black wires should be connected to the switch. Do a voltage check between the blacks and the ground (with switch on). If you have voltage there the breaker is not tripped. If you don't have voltage the breaker is tripped or a GFI is tripper somewhere. If you don't have a volt meter stope by Home Depot or Lowe's and pick up one for about $15.
At the fixture the blacks should be wire nutted together and to the black of the fixture. The white wires should also be wire nutted together and to the white of the fixture.
Harold,
Old 02-10-2019, 11:33 PM   #12
dmxtothemax's Avatar
Rewards Points: 7,324
Do you have any testers ?
If so what tests have you done ?
FrodoOne likes this.
dmxtothemax is offline   Reply With Quote
Old 02-11-2019, 02:08 AM   #13
Guapo
Rewards Points: 11,950
What about a lost neutral?
Guap0_ is offline   Reply With Quote
Old 02-11-2019, 05:13 AM   #14
Rewards Points: 2,360
There are many good suggestions on this thread for mschmied89
No matter what mschmied89 may think, if it is not a fault with the Breaker at the Panel, the fault is an open-circuit in either the Line, Switched Line or Neutral connection to either the Switch or the Lamp connection(s) - probably caused by his activities.
You have not answered this question.
However, in a previous post you wrote "I used a voltage tester to determine that it was live."
While "voltage testers" of this ilk may have some use, please forget it for your present problem and obtain a cheap analog multi-meter, such as https://www.amazon.com/Gardner-Bende...ords=analog+mu
Do not be tempted to obtain a Digital Meter.
(You may also need to obtain a long length of wire to connect to a Ground Point.)
Then, use this meter to determine if you have
120 V AC between the Line connected to the input of the switch and any available Ground point.
Then, check that the Switch controls the output Switched Line connection - so that it can be turned On and Off - when tested against the Ground point.
If that is so, check that (when the switch is On) there is 120 V AC at the input to the light fixture.
(The above checks the continuity of the Line and Switched Line connections.)
If so, check at the light fixture that there is 120 V AC detected between the Switched Line and the Neutral connection.
(This checks if the Neutral has continuity back to the Panel - and the supply.)
Somewhere along this trail you will discover the open circuit connection which is the cause of your problem.
FrodoOne is offline   Reply With Quote
Old 02-11-2019, 07:57 AM   #15
Property Mgt/Maint
Possibly the socket adapter is not reaching the center contact.
On a seldom occasion I have run into a light bulb that would not reach the center contact tab in the socket. For what ever reason, maybe the tab is bent or warn down, or maybe the male thread assy is a little out of spec. In any case the remedy is simple. Be sure to de-energize first and then lift the center tab up a little with a screw driver.
Hidyi and Domo like this.
Open Hot, Still Use Power? n00b3 Electrical 3 01-07-2016 11:50 AM
What size power fasteners and power loads elmaur Carpentry 3 06-12-2015 07:27 AM
Power problems on second floor, first floor is fine rarken1 Electrical 21 05-16-2015 11:42 AM
California Home Power limits? (5+ computers in 1 room) jazzman170 Electrical 34 10-02-2014 10:37 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
