No Ground In Garage - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-28-2016, 09:00 PM   #31
Rewards Points: 774
Re: No ground in garage
Originally Posted by rjniles View Post
Except you are bonding the neutral to ground at 2 different locations for a single service.
Where is the issue, the utility bonds the neutral at the pole runs a 3 wire to the house, you bond at the house. Here he has a 2-wire there is no parallel current unless as noted below.
For me I would prefer a grounded system.
Can you point to one problem with this set up IF there is no metallic connection (water or gas pipe most common) between the house and garage?
You would prefer an ungrounded system? As noted this was an accepted standard in the NEC, changed sometime last decade.
Know A Little is offline   Reply With Quote
Old 04-28-2016, 09:16 PM   #32
Rewards Points: 516
It is a grounded system! At the service disconnect. There's no reason to make it a grounded system in two different points! That's why the code updated! It is better to be grounded at one point rather than multiple! Earth gradians, objectionable current, touch potential!
Arrow3030 is offline   Reply With Quote
Old 04-28-2016, 09:56 PM   #33
Rewards Points: 774
No! There will be no objectionable currents UNLESS you agree every service in the US has objectionable current (which many due due to sharing metallic piping). Every service is grounded at the pole and in the residence and i many cases multiple residence. Do you agree with that statement?
You are saying you would prefer an ungrounded system?
Old 04-29-2016, 12:06 AM   #34
Rewards Points: 516
It isn't objectionable if it's intended and for good reason. Making multiple loops on a single service was banned a decade ago. Why defend it?
Old 04-29-2016, 05:44 AM   #35
Rewards Points: 774
Don't answer my question regarding safety and multiple grounded system on a single transformer is very common.
You have your opinion which is valid and I have mine that is valid. Take care.
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Ground wearing out from under garage concrete pad vernonl Building & Construction 4 05-24-2011 02:53 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
