NM From Interior Wall Direct To Exterior WP. - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By xjfan
Old 10-17-2016, 09:53 PM   #1
Rewards Points: 18
NM from interior wall direct to exterior WP.
Hello everyone,
Hope I'm able to explain my question correctly.
I got some input from an electrician who is assisting.
We need 10/3, 220v, 20amp circuit in a junction box mounted on a brick exterior wall.
The NM 10/3 has been run down the interior wall and now needs to be ran through the brick exterior wall.
My question: Best method. These options were provided.
1: Could 90* gray 3/4" pvc be used in the wall to bring the cable out directly to the back of the box?
●Pvc pipe with male adapter connects to the back waterproof box.
2: Should a metal box be install inside the home, gray 3/4" pvc in back of it. Pvc pipe connects to the back of the outside metal waterproof box?
●Cable runs in the top of interior box, secured with clamp.
●Short pvc pipe has male adapter that connects to inside and outside boxes.
3: Run NM cable through the wall, no conduit, directly into the back of the exterior box. NM cable secured using romex clamp on junction box?
● Cable stapled to interior studs. Once cable is ran through the wall, clamped to connector in back of box , fill void with silicone. Run a bead of silicone to top and sides of box.
Thanks in advance.
Joe
xjfan is offline   Reply With Quote
Old 10-17-2016, 09:59 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 952
Re: NM from interior wall direct to exterior WP.
Option 1 is what i do.
Why 10/3 for the 20 amp circuit?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 10-17-2016, 10:04 PM   #3
Rewards Points: 312
Yes, you can do that. Its more than what's needed......no need for PVC pipe in the wall.
No need for a metal box on the inside. That interior box would require accessibility in the future, which could complicate your future interior plans. No need for it.
Yes, in my opinion, this is your best option.
NOTE: If this is for an AC condenser, you'll need a manual disconnect on the outside instead of a junction box.
Hope this helps.
Power- is offline   Reply With Quote
Old 10-17-2016, 10:24 PM   #4
Rewards Points: 18
It's a sewer grinder pump. Distance from electrical panel to pump control panel is approx 125'. We thought it'll be safer to run 10/3 instead of 12/3.
jbfan likes this.
Old 10-17-2016, 10:38 PM   #5
Rewards Points: 18
Re: NM from interior wall direct to exterior WP box.
I was reading on various sites. Some indicates nm needs to be protected because a small amount us exposed.
Others indicate, just run the cable through the wall directly to the back of the box.
I wasn't sure which way was best.
Plumbing part will be inspected, not sure about electrical. I'll follow up with plumber to confirm.
Old 10-17-2016, 10:44 PM   #6
Rewards Points: 312
In the commercial industry, we call those ejection pumps.
You may want to run another low voltage cable with your 10/3 out to the pump. REASON: Some customers want hi-level audible alarms to inform owners the tank is too full. Black water waste tanks have floats that control the ON/OFF of the pump, but also have a hi-level alarm float that is used for warning about a pending overflow.
Old 10-17-2016, 10:52 PM   #7
Rewards Points: 18
Re: NM from interior wall direct to back of exterior WP box...
Good idea. I know the panel has alarm and light. I'll look into running low voltage also. Might as well. Wall has been opened up. Thanks.
Direct Vent Water Heater Question kc27 Plumbing 2 02-12-2014 01:39 PM
Jaz's experience with BUILD DIRECT JazMan Flooring 1 06-08-2013 08:24 PM
direct venting question bubbler HVAC 3 10-07-2011 05:16 PM
Simpson Dura-Vent or Amerivent Direct Vent System? Fire4Effect HVAC 0 10-15-2009 02:39 PM
Direct Vent or Free Gas Fireplace rocketdoctor HVAC 1 04-12-2009 06:47 AM
