DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   NiChrome hot wire to cut foam?? (https://www.diychatroom.com/f18/nichrome-hot-wire-cut-foam-51794/)
bruter 08-27-2009 01:09 PM
I'm trying to set up a hot wire 24" long so I can slice a piece of foam in half.
I thought I would fasten the wire to a work bench somehow and heat up the wire and push the foam through the wire. The foam is 4" thick and 2' x 4'
I want it to be 2" thick. I don't know how to set up the wire or what gauge to get or how to make it hot. Any help would be appreciated.
300zx 08-27-2009 02:43 PM
I have never made one, there are a couple of websites http://members.fortunecity.co.uk/slmohr/rcinterest2.htm http://www.youtube.com/watch?v=03u1Hf7Dm5I
micromind 08-27-2009 07:09 PM
Occasionally, I do electrical work at a styrofoam factory that uses hot wires to cut the product.
These are stretched across a table, and the foam board is fed into the wire. It makes very clean cuts.
The wire is fastened rigidly on one end, and attached to a spring on the other. The wire will grow lengthwise as it is heated, and the spring keeps it from sagging.
The power supply is a constant current type. It's DC output, but only because it's easier to control DC current than AC. AC or DC will work just fine. Current is maintained, and voltage falls wherever it will. Voltage is not high enough to be hazardous, so no insulation is needed on the Nichrome wire. It will cause serious burns though.
You'll need to experiment a bit to get the right temperature, too cold and it doesn't cut well, and gums up the wire. Too hot, and it'll smoke a lot, and the cuts will be rough.
Rob
220/221 08-27-2009 07:56 PM
Use a car battery for power and find a simple component to regulate the voltage.
Gigs 08-27-2009 08:10 PM
Heh, which would be??
The only simple thing I could think of is making your own wirewound resistors out of some spare nichrome wire wrapped on something that won't burn. You would have to experiment with the length to get the heat level you need.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
