New Service Line In Garage... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 08:38 AM   #1
NYC
New service line in garage...
What is the best way to run a new service line in my garage for a workbench? The panel is in the garage and the outlets will also be in the garage. Would you run it outside in conduit or cut the dry wall so you can run it inside the wall and not have it show?
Opinions??
Dennis1188 is offline   Reply With Quote
Old 10-21-2010, 09:06 AM   #2
Just call me Andrew
Rewards Points: 1,032
If the panel and new outlets are both in the garage, then don't bring it outside. Why expose it to the elements for no reason? You can either cut holes in the drywall and drill holes in the studs, or run on the surface of the drywall in a raceway to protect it from damage.
Andrew
secutanudu is offline   Reply With Quote
Old 10-21-2010, 01:34 PM   #3
Licensed electrician
Rewards Points: 3,654
If the garage is attached to the house you will need to preserve or restore the integrity of the firewall.
Looking to run gas line to garage...plumber wants to know the BTU's HautingLu HVAC 2 07-15-2010 06:24 AM
What kind of service line to install? 62Galaxie Plumbing 6 01-26-2010 01:01 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
electric service in garage kelr Electrical 2 03-26-2005 08:38 PM
