New Room Ground Issues - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Oso954
  • 1 Post By Oso954
  • 2 Post By jimn01
Old 11-04-2017, 02:47 PM   #1
Rewards Points: 24
I recently built a new room and the person that helped did not connect the ground wire at the electrical box or each outlet. He installed three switches, 2 x 20a for the room that contains 3 outlets a piece and a 15a for three can lights. I'm focusing on the outlets first and noticed that the copper was cut back.
Here's what I've performed to date:
1. In the breaker panel, I connected the new wire copper to an open slot in the same bus as the other copper wires.
2. For outlets that piggyback to other outlets, I used a connector with two inputs to extend the copper cable, and a connector with three inputs to connect the extensions to a pigtail that is secured at the green screw on the outlet.
When I plug in a surge protector, it's still lighting up red next "site wiring fault," but still works (validated the light turns off on other outlets). Any recommendations on why this is still not properly grounded? Is there potential that I connected it incorrectly to the breaker box or there's a loose piece of copper in one of my connectors?
Arch50 is offline   Reply With Quote
Old 11-04-2017, 03:00 PM   #2
Oso954's Avatar
Rewards Points: 900
Re: New Room Ground Issues
I think your hots and neutrals are reversed.
Hots (blacks) should be on the brass screws, neutrals on the silver.
CodeMatters likes this.
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Arch50 (11-04-2017), Jim Port (11-07-2017)
Old 11-04-2017, 03:11 PM   #3
Rewards Points: 24
Thanks, Oso! I just painted the stairs so will have to wait until tomorrow. So the grounding may now be connected properly and the fault light is throwing based on hot/neutral not connected properly? If so, easy fix and will validate with each.
Old 11-04-2017, 03:26 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,364
Guessing you hired a handyman and not an electrician!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 11-04-2017, 03:31 PM   #5
Rewards Points: 24
Something along those lines.... Hoping Oso's recommendation of hot to brass fixes the wire fault light.
Old 11-04-2017, 04:32 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 30,542
Based on your picture it sure looks like the hots are on the silver screws.
Old 11-04-2017, 05:03 PM   #7
Naildriver
chandler48's Avatar
Rewards Points: 1,304
The hots ARE on the silver screws, which are on the side of the green ground screw. Also, turn the shepherd's crook around on the grounding wire. It should be clockwise so it tightens up when you tighten the screw. You have quality receptacles, so you can use the pressure plates on the hots and neutrals without bending the wires.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 11-04-2017, 05:05 PM   #8
Oso954's Avatar
Rewards Points: 900
Why the 20amp switches ?
I see 14 gauge (15 amp) wiring in the pic. I hope that receptacle is on a 15 amp breaker, not a 20.
Blue Marjan likes this.
Old 11-07-2017, 08:29 AM   #9
Rewards Points: 125
The simple screw ups in this photo make me wonder what else was done wrong. Personally I would be kind of nervous about this electrical install.
47_47 and CodeMatters like this.
jimn01 is offline   Reply With Quote
Old 11-07-2017, 09:00 AM   #10
CodeMatters's Avatar
Rewards Points: 7,478
Me too. I'd redo everything he touched.
CodeMatters is offline   Reply With Quote
Old 11-07-2017, 11:48 AM   #11
Super Moderator
joed's Avatar
What is your location. If you were in Ontario you could report him to the ESA.
https://www.esasafe.com/licensing/co...ons-unlicensed
Old 11-07-2017, 11:59 PM   #12
Rewards Points: 24
Thanks for all of the great advice. I purchased an outlet tester that determines if hot/neutral is incorrect, not properly grounded, etc. Happy to say, no errors after addressing the issues. Here's the remediation:
1) Removed both 20a breakers and replaced with 15a breakers given the 14g wiring
2) Reversed black/silver to black/gold on all outlets
3) Identified that on the second 14g run, there was a splice to extend the wiring and only the hot/neutral was capped. Stripped back the copper and connected and the rest is history.
Thanks again to everyone. You really helped me improve the safety of my new room. Now onto determining how to check if the three can lights installed were grounded or not....
Adding ground to a room liljoey112 Electrical 10 06-02-2013 01:19 AM
Room Addition Second Story vs Ground Floor Add On Topcat Remodeling 5 07-27-2011 09:17 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 07:31 PM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
