New Outlet For Wall Mounted TV - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2017, 05:59 PM   #1
Rewards Points: 112
I want to hang my tv on my wall, but the closest outlet is a half hot, switched outlet. Can someone please provide a wiring diagram>
ashtonallen is offline   Reply With Quote
Old 11-12-2017, 06:15 PM   #2
Licensed electrician
Rewards Points: 3,840
Re: New Outlet For Wall Mounted TV
If the existing box has space you would add a new cable and pigtail color for color into the constant hot side of the receptacle .
Old 11-12-2017, 07:30 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,530
While you are at it, you may as well entertain handling your low voltage stuff. HDMI, coax, RCA, etc. can be run in a dual box like below and the receptacle is angled so as not to take up space with the plug hanging out.
https://www.homedepot.com/p/Legrand-...WCC2/202529126
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 11-12-2017, 07:40 PM   #4
CodeMatters's Avatar
Rewards Points: 7,952
Arlington is another maker of outlets designed to go behind TV mounted
on walls.
http://www.aifittings.com/landing/tv-box-series/
CodeMatters is online now   Reply With Quote
Old 11-12-2017, 09:48 PM   #5
Rewards Points: 112
Just making sure I understand, I would join the new wire, the old wire, and a spliced cut section with a wire nut. Then attach the open end of the cut section to appropriate screw?
Old 11-12-2017, 10:14 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,940
yes that is correct
No power to light switches and outlet Deco Electrical 6 09-12-2017 01:13 PM
protruding outlet, outlet cover cracked custard Electrical 1 07-09-2017 11:33 PM
How much can you connect to an outlet? cpgoose Electrical 10 12-17-2014 11:24 AM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
