New Outlet Using Power From A Nearby Switch. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 09:29 PM   #16
" Euro " electrician
frenchelectrican's Avatar
Dave.,
Now you can understand why I hate 18 inch boxes they are plenty small for most case I useally use the deep one that come in 21 cubic inches that is deeper verison and all the switches box I install my SOP is use the deepest one you can get that way I don't have to worry about if dimmer or fan speed control is installed that will really eat up the room if not carefull with it.
to OP
The one good way you can do is cut out the old plastic box and install the smart old work box it will come with side screw so you can able rescrew into the stud.
This item one of few items I do carry but I have to show it so you can understand it more clear and the photo will show one gang verison
http://www.smarthomeusa.com/ShopByMa...Box/Item/SB22/
Of course there are other size as well.
Merci.
Marc
Old 10-15-2009, 09:33 PM   #17
Yeah, I just bought a box of 100 of the 22 cu in boxes
If I needed more then 62 boxes then the price on the 100 was the same
Surecook - keep in mind my calcs are based on 14g wire
12g wire is 2.25 cu instead of the 2.0
Thanks - my house is getting there...lots of work
Old 10-15-2009, 09:39 PM   #18
Wow Dave that good move to get in box quality normally that what I always do that due from my electrical supply centre I get price break by get in box full some time in case or pallet quality
But for other stuff it will varies depending what I run into. { most conductor or cable I get them in large spool if I can }
Merci.
Marc
Old 10-16-2009, 11:19 AM   #19
Where can I buy smart boxes?
surecook is offline   Reply With Quote
Old 10-16-2009, 11:39 AM   #20
300zx's Avatar
the link that frenchelectrican gave you in his post #16
300zx is offline   Reply With Quote
Old 10-16-2009, 12:01 PM   #21
I also noticed my math was off
12 for conductors
2 for grounds
2 for device
Total 16 cu in right now, not 18
Old 10-16-2009, 12:51 PM   #22
@300zx I was hoping I didnt have to order them from the site. Would rather go to The Depot or Lowes.
Thanks Dave - looks like I wont need to install a new box after all.
Old 10-16-2009, 12:56 PM   #23
The 16 cu inches is right now
Adding another 14g cable (15a) will require another 4 cu inches = 20 cu in box
Old 10-16-2009, 06:27 PM   #24
Since I am a novice here are a few pictures.
It's worth a thousand words.
The black and white capped wires are your power.
Don't bother changing the box. Cut those wires a bit shorter and they will fold back in there nicely. If your "make up" is clean, you can easily fit "extra" wires in a box. If your make up sucks, a bigger box won't help.
220/221 is offline   Reply With Quote
Tags
electrical
Replacing Light Switch & Outlet, but now I'm confused. ego1138 Electrical 7 04-25-2009 04:49 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 08:36 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
Outlet switch for a/c helpless handyman Electrical 10 06-10-2008 01:49 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
