New Outlet On Existing UF Wire - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By Jim Port
Old 07-17-2017, 11:12 AM   #1
Rewards Points: 4
New outlet on existing UF wire
I am trying to repurpose some existing UF wire. It currently goes through my foundation, with no conduit involved, about 14" below ground and runs a long way to a place that does not need it.
I would like to cut it short and bring it up to slightly above ground level to a new outlet that would be mounted on the side of the house. I have a weatherproof cover, GFCI outlet, and metal box with top/bottom holes to connect to conduit.
My question is: am I meeting code if I:
(1) just bring the UF directly into the metal box (from the bottom)?
(2) put the UF in a metallic conduit, which would run to near the underground location near where the UF currently goes through the foundation?
(3) or, least favorite choice, do I need to cut a new hole and run conduit from inside the foundation hole, through the foundation, through the dirt, and into the outlet box?
Would doing either option (1) or (2) and somehow sealing the entry point of the UF be sufficient?
(This is in Montgomery County, MD, which uses 2012 NEC, I don't believe there are any relevant local modifications)
Thanks in advance,
Michael
fivetimesfast is offline   Reply With Quote
Old 07-17-2017, 12:11 PM   #2
Licensed electrician
Rewards Points: 4,248
Re: New outlet on existing UF wire
Your plan 1 sounds ok except you will need to sleeve the cable from 18" below grade to the receptacle .
J. V., csab_ and fivetimesfast like this.
fivetimesfast (07-17-2017)
Old 07-17-2017, 12:26 PM   #3
Rewards Points: 637
Yes; you also need waterproof box and weather resistant receptacle.
BTW there is no 2012 NEC. 2011, 2014, 2017.
csab_ is offline   Reply With Quote
Old 07-17-2017, 12:29 PM   #4
Oso954's Avatar
Rewards Points: 2,140
He's on NEC 2014, with local amendments.
Oso954 is online now   Reply With Quote
Old 07-17-2017, 02:21 PM   #5
Rewards Points: 4
Thanks for the quick feedback, and also for the 2012/2014 mistake (the 2014 is sitting right in front of me, not sure what I was thinking about). I'm going for Plan #1.
Tags
conduit , foundation , outdoor , outlet , uf wire
Running A New Outlet from An Existing Outlet sethmac Electrical 2 11-25-2014 05:17 PM
Wire an outlet to 2 outlet jfmartel Electrical 10 07-17-2014 09:26 PM
Feed 2 circuits with three wire at outlet? Dansteel17 Electrical 23 11-01-2013 04:38 PM
wire ceiling fan to outlet switch((help)) tommy281 Electrical 10 11-02-2009 09:15 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
