New House Construction Need Wiring For Solar - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 01:09 PM   #16
Remodeling Contractor
yes I meant it. the OP is referring to specific wiring for an unknown load and/or device. Designing a clear path to allow any future access between these points is far less costly and far more useful for future use. As to the 12/2. Any electrician worth a damn designs the system for future use. More space in load centers. More total load capacity than currently needed. And a 12/3 to the attic junction box is almost always done.
Old 01-06-2010, 02:15 PM   #17
Originally Posted by TitaniumVT View Post
Just out of curiosity, how does an intertie solar panel system physically connect to your house electrical system?
They are connected through a safety interlock. If you just tie them to the main panel then you'll potentially electrocute linesmen working on what should be cold wires.
There is one interesting device I read an article on. It's a little box that the panel plugs into. Then the box plugs into an outlet. The interlock is somehow built into the box. It feeds the power from the solar pannel onto the grid (reverse metering). It works even places where reverse metering isn't legal, so the Mother Earth people called it Guerilla Solar. They said it was so costly that the payback period was silly long, but they liked the idea anyway
pyper is offline   Reply With Quote
Old 01-06-2010, 02:36 PM   #18
I can't see how you can run wire now to connect an unknown solar system
They can range from a few 200w panels up to an 8,000w setup + higher
The 1st one you could get by with 12-2 run, the 2nd depending upon the setup you would need 4 12-2 runs or one single higher gauge run
My future system will be wired thru the attic, so I have access
If I did not (have access) I would not run wire for something that is unknown
Many people ran CAT3 runs years ago for computer devices & the runs were never used
A complete waste of $$ at $90 a run in commercial buildings
Old 02-14-2010, 01:14 PM   #19
Do a solar.(D.C output) suply a house? Or just carry load on d.C apyance alone in d house! Or is been connected 2 an invertar first 2d suply A.C current 2 d house...d solar i hv seen.suppy d.c radio only
viktur is offline   Reply With Quote
Old 02-14-2010, 01:18 PM   #20
You can supply DC to a house
There are underfloor heating setups that I looked into that use striaght DC power from solar panels
But here most people use an inverter & covert the power to standard 120v power for use
People do use DC - usually when they are off grid, cabin in the woods etc
Pole house construction plans Woolly Locust Building & Construction 4 01-02-2010 04:28 PM
Problem with wiring (really long post sorry) okacookie Electrical 10 04-21-2009 08:54 AM
DSL slow inside house - wiring options mcvane Electrical 18 07-14-2008 03:15 PM
60 year old house wiring bigp58 Electrical 1 04-21-2008 11:32 AM
