New Garage Lights - Tripping Breaker / Sparking Switch - Electrical - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By Oso954
  • 2 Post By rjniles
  • 1 Post By fusebox7
  • 1 Post By schreibdave
  • 1 Post By surferdude2
Old 12-08-2019, 11:48 AM   #1
Rewards Points: 34
Hello to all - looking to get some input on where I can diagnose my issues before shelling out to hire an electrician to come out.
We had 3 old wall-mount outdoor light fixtures that we replaced on our garage. Simple project - one I've done many times before (white-to-white, black-to-black and copper-to-copper ground). This time around, when I finished the install, screwed in some bulbs, flipped on the breaker and then turned the switch to the "on" position, my garage door light flickered (hz wave?) and the breaker tripped (without the new bulbs turning on in the new fixtures).
I figured I had some wires touching causing a short so I took each fixture down and re-inpected and re-wire-nutted each with no visible issues. I tried the process again and this time when I turned on the switch, it sparked, so I quickly turned it off. The breaker did not trip this time. I've had the circuit off because I don't know what to do next.
Of note is that there are two switches for this circuit - one at two entries to the home. The first attempt I used one switch, the second attempt I used the second switch (the one that sparked).
Any obvious things that I should be looking for or testing? I haven't had this type of issue before and am at a loss as to why it's happening. I currently haven't been able to run a refrigerator in the garage and garage doors due to the circuit being off.
I did try LED bulbs first (8 watt x 3 bulbs) and then I tried 53 watt incandescents - neither worked.
Thanks in advance for any helpful hints!
fusebox7 is offline   Reply With Quote
Old 12-08-2019, 11:52 AM   #2
CodeMatters's Avatar
Rewards Points: 7,628
Re: New Garage Lights - Tripping Breaker / Sparking Switch
Could be a short inside one of the new fixtures.
With power off, check the circuit for a short with ohm meter.
Open the cct in logical places to isolate short.
CodeMatters is online now   Reply With Quote
Old 12-08-2019, 11:58 AM   #3
Rewards Points: 34
@CodeMatters - thanks. That's what I figured I'd have to do next is just test with a multimeter in various places to at least try to isolate the issue. I have a buddy coming over to help. I'll report back to see if that yields and findings. Hopefully it's not the fixtures - they were custom made and took a long time to be produced. Maybe when installing them I had a pinch and insulation came off or something is getting grounded. I'll find out... hopefully.
Old 12-08-2019, 11:59 AM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,132
Fuse.... Sounds like you have not re-wired as before.
In three way switches, the wire colors and switch terminals are easily mixed up.
I'm sure someone will be along to show you pics of three way wiring (I don't know how to find/load them).
Then if that does not help, we'll have to ask specific questions/pics if exactly what you have to correct it.
As a preliminary question, do you have a multi-meter and know how to test for voltage and/or continuity
MTN REMODEL LLC is offline   Reply With Quote
Old 12-08-2019, 12:30 PM   #5
Oso954's Avatar
Rewards Points: 1,274
The problem with wiring that way is that not all whites are neutrals. Whites are used as power carrying wires in switch loops or in multi-switch configurations as a traveller.
While there is a requirement to mark those white wires that carry power, it doesn’t always happen. In fact, it is a rarity in some areas.
My guess is you connected a white power wire to a neutral and now have a direct short.
Btw, is this a detached garage ?
MTN REMODEL LLC likes this.
Oso954 is online now   Reply With Quote
Old 12-08-2019, 12:52 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 328
Remove the fixtures and clear the wire ends. Try the switch. If it holds, with the power off instal a fixture and test again. Rinse and repeat.
Sent from my RCT6A03W13E using Tapatalk
bob22 and afjes2015 like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 12-08-2019, 01:14 PM   #7
Rewards Points: 34
@Oso954 The only thing I can think of is that everything is flipped backwards where the white and the black are not the traditional common vs. load.
The fixtures passed the continuity test so they can be crossed off the list.
Should I try wiring the ribbed light fixture wire to the black lines instead of the white as they are now?
EDIT: and it is an ATTACHED garage.
Old 12-08-2019, 01:16 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 328
Even if that were true, it would not trip the breaker.
Old 12-08-2019, 01:18 PM   #9
Rewards Points: 34
@rjniles @Oso954 - the old light fixtures had black to black and white to white... the only difference with the new fixtures is that the "ribbed" is supposed to go to "white" and the "smooth" to black (which I have done).
chandler48 likes this.
Old 12-08-2019, 04:33 PM   #10
surferdude2's Avatar
Rewards Points: 1,506
Some users find it safer, easier and cheaper to use a series test light at the breaker feed point to help isolate and locate a short circuit. What is needed is a standard light bulb socket with pigtail wires coming from it. Disconnect the breaker wire and connect the test bulb wires in series with the breaker lug and the wire that was removed. Turn on the breaker and the bulb will light with normal brilliance to show that the line is shorted. Proceed along the feed path, disconnecting fixtures from the far end back toward the panel until the light goes out. Using Vulcan logic, you'll know where the short may be.
Generally, using that same Vulcan logic, it will be something you worked on recently.
ps. Believe it or not, in older days, much older days, electricians used to stick their finger inside a light bulb socket or onto a wire to see if it was live! True fact.
Stay safe, don't work on any connections while they are live!!! Good luck in the quest.
surferdude2 is online now   Reply With Quote
Old 12-08-2019, 05:35 PM   #11
Rewards Points: 34
It took all day and following the advice posted here (THANK YOU) but we (believe) we found the culprit... one of the screws used to attach the fixture had rubbed the insulation off of the load wires (CRAMMED IN THE BOX) and since the bracket plate is grounded it was shorting the circuit.
I still have the wires in reverse polarity due to the horrible fixture instructions (marked wire to white... marked meaning wording/labeling?). But that will be an easy swap.
Thanks all - problem solved. Deductive reasoning wins this time!
Old 12-08-2019, 05:43 PM   #12
Common failure, fixture screw runs through the wire insulation. Ribbed or otherwise id'd is always neutral (white).
All the best, SD2
Old 12-08-2019, 06:34 PM   #13
Collector of tools
Rewards Points: 144
Wow. I've never heard of that trick. So pig-tailed socket is inserted in series(one pigtail towards breaker, one out to the fixtures on the hot wire) and if there is a short further down the line the light will come on? And that's because there is a continuous circuit back to the panel or some other source of ground? Thanks for that.
surferdude2 likes this.
schreibdave is offline   Reply With Quote
Old 12-08-2019, 06:46 PM   #14
That was common practice years ago when all sub panels used screw-in fuse protection, breakers were high tech back then or didn't exist yet. The electrician just screwed a light bulb into the fuse socket (same size and fit as a screw-in fuse) to do what I described. When out of fuses and one blew, some homeowners would put a copper penny in the socket and screw a blown fuse in to hold it against the contacts to substitute for a fuse. Sometimes we read about those people in the paper!!!
You can learn a lot from an old dummy!
ps. Repeatedly closing a circuit breaker into a short circuit is not only risking damaging to it, it can be dangerous to the operator. The possibility of the instantaneous short current exceeding the SCCR (short circuit current rating) of the breaker is ever present. It can blow up into a fireball of plasma and shrapnel that can do great harm to the unsuspecting operator. This is especially true when houses are built close together and dual fed from a daisy chain open loop at each end. The person closest to any given transformer may be subject to tremendous instantaneous high short circuit current levels, all the way down to the final load on any branch circuit. Current code requires an adequate level of SCCR of all connected device in order to mitigate that risk.
schreibdave likes this.
