New Construction Wiring. What Was The Builder Thinking - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By supers05
Old 09-13-2018, 01:41 PM   #1
Rewards Points: 48
New construction wiring. What was the builder thinking
I'm looking at the low voltage pre-wiring for my garage door opener. (The wiring for the safety sensors)
I have 3 garage doors. At two of the doors they have prewired TWO cat5 type cables on ONE side of each door. On the third door there is only 1 cable there.
Why did they put two wires at each of two doors, but only 1 cable at the other door? (Note at the outlet in the ceiling there are only 2 cables for each opener, presumably 1 for the safety and 1 for the push button.)
I was able to wire one of the doors thru trial and error, using 1 of the 2 sensor wires. However I'm now working on the door which includes only 1 cable, and I can't get power to the sensor thru that wire.
Is there any logic to their madness, or did they just mess up?
edfiero1 is offline   Reply With Quote
Old 09-13-2018, 02:29 PM   #2
Rewards Points: 418
Re: New construction wiring. What was the builder thinking
I can't see how they routed the wires but my guess was they were a tad lazy and intend the two wires to have one go to one door and the other run along the baseboard to the other door next to it. This is assuming that the two wires are routed between the two doors and not all the way on one end or the other. The third, single wire I am guessing is at an end. Even with this methodology you need six wires so I'm not sure how they intend to accomplish this.
Sdiver2489 is offline   Reply With Quote
Old 09-13-2018, 03:41 PM   #3
Rewards Points: 80
Was it just a rough in, or were they supposed to install these door openers? Rough ins not used by closing, can be missing things.
Cheers!
supers05 is offline   Reply With Quote
Old 09-13-2018, 08:48 PM   #4
Maintenance / Locksmith
Rewards Points: 316
How many individual wires in each Cat 5 cable?
georgemcq is offline   Reply With Quote
Old 09-14-2018, 07:31 AM   #5
Rewards Points: 48
There are like 4 pairs of wires in each cable. Green - Green White, Brown - Brown White, Orange - Orange White, etc.
Old 09-14-2018, 07:33 AM   #6
Rewards Points: 48
Cheers!
This is just a rough in. I am installing the openers myself.
The garage has been drywalled so I can't see where the cables are going.
Just can't understand why 2 of the doors need 2 sets of cables. And the door with only 1 cable.... doesn't seem to terminate at the overhead location for THAT door.
Old 09-16-2018, 12:24 AM   #7
Rewards Points: 80
Depending on the sensor, you'll need 2-4 wires per sensor. Some use a reflector, instead of a double line sensor. That would mean only a single cable to each door, plus another for each keypad outside the door.
Cheers!
Old 09-16-2018, 07:31 AM   #8
CodeMatters's Avatar
Rewards Points: 7,624
You either pay for the job to be completed, or you deal with picking up
where an installer, who couldn't care less, left off.
CodeMatters is online now   Reply With Quote
Old 09-16-2018, 07:36 AM   #9
retired framer
Rewards Points: 8,556
Cheers!
The key pad outside would be wireless.
CodeMatters likes this.
Old 09-16-2018, 08:28 AM   #10
Rewards Points: 80
You guys got nicer products. All the subdivisions here have wired keypads, if you get anything at all. Cheapest stuff they could find.
Cheers!
Old 09-16-2018, 08:32 AM   #11
retired framer
Cheers!
So you smash the plastic and cross the wires and your in.
Here they just steel the key pad but they can't get in.
Old 09-16-2018, 08:33 AM   #12
Rewards Points: 80
Here they would just drive through the door anyways... Lol. Locks are for honest people.
I didn't say it was secure, i said it was cheap.
Cheers!
Nealtw likes this.
Old 09-16-2018, 10:59 AM   #13
Any I've seen in Eastern Ontario (and that's a lot of them) have all been
battery powered wireless keypads.
Old 09-16-2018, 11:05 AM   #14
Rewards Points: 80
It's definitely smarter. The house that I just moved into is wired. I disconnected it inside, as its not needed. But then any universal remote will open it when set to the right frequency.
Cheers!
Old 09-16-2018, 04:50 PM   #15
Rewards Points: 316
Are the 3 doors in line with just a small partition between them? If so, you have all the wires you need if the wires are on the outside of the openings. Please post a picture(s)
. [ ] . .[ ]. [ ]. [ = door openings & . = wires
Old House Wiring Traycam Electrical 14 01-03-2015 09:31 PM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
recepticale wiring /new construction Stcrosby Electrical 10 04-07-2013 02:42 PM
Pre-planning new construction - sch 40 conduit in exterior walls? WillK Electrical 1 11-30-2012 08:10 AM
