New Buried Line For Outdoor Pool - Electrical - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 1 Post By Oso954
  • 3 Post By J. V.
  • 1 Post By DeeEyeWhy
  • 2 Post By Speedy Petey
  • 1 Post By mpoulton
  • 1 Post By Speedy Petey
Old 05-01-2017, 12:09 PM   #1
Rewards Points: 194
New buried line for Outdoor Pool
My town follows the NEC 2008 code, so from my understanding (and I may be wrong) that means direct burial down to 18" below ground level. My pool will be located about 35 ft from the house. It will be an above ground 52" high pool.
  1. What type of breaker? GFCI or AFCI?
  2. What type of wiring? Should I run THHN wire in conduit or can I use this UL rated Romex: http://www.homedepot.com/p/Southwire...5955/202316281.
  3. How high from the ground should the receptacle be?
  4. How to secure the receptacle if it is not near a structure?
  5. Any special grounding that needs to be done?
  6. Anything else that I am missing?
DeeEyeWhy is offline   Reply With Quote
Old 05-01-2017, 02:14 PM   #2
Oso954's Avatar
Rewards Points: 1,836
Re: New buried line for Outdoor Pool
You need to get hold of article 680 of the NEC and read the requirements for pool installation. Some of the requirements are very different than than ones you are used to.
Because of the differences in the requirements and the hazards envolved, I would recommend that you hire a electrician. Whether he does it all or directs you for parts of it, is something you can discuss with him.
After you read article 680, you will be in a better position to ask questions.
No, you cannot use the UF cable. It doesn't have the green insulated conductor required for a pool installation.
Yes, you will have special bonding requirements in addition to the normal EGC "grounding".
FYI, because of the water depth of your pool, it is considered a permanently installed pool, not a storable.
mpoulton likes this.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Speedy Petey (05-01-2017)
Old 05-02-2017, 12:52 PM   #3
J. V.'s Avatar
Rewards Points: 578
Don't try to do this yourself. You're not an electrician and even seasoned electricians that rarely do pools might turn jobs like this down.
You at minimum need professional help and or guidance.
Let the pro make your job safe and compliant. Do not expect to read Art 680 and get it right, either.
Jim Port, Bria Johnn and mpoulton like this.
If it worked before you worked on it. You did something wrong.
Old 05-02-2017, 12:55 PM   #4
Rewards Points: 194
I called a few electricians to get some estimates so we'll see how that goes. I am guessing I can help dig the trench to save some cash on the install of the conduit. :-)
bob22 likes this.
Old 05-07-2017, 12:36 PM   #5
Rewards Points: 194
Hey guys, a little update and more questions:
I called a couple of electricians to get estimates for the line and trench work and to say the least i got estimates on both ends of the spectrum and i dont know what to believe here.
To install one 20A line with GFCI receptacle, cooper bonding around pool, skimmer and feeder, dig trench and put back dirt afterwards:
Guy #1: $600
Guy #2: $2,400
Both are licensed, but guy #1 is older and more seasoned when you speak to him. i liked Guy #1 better from the beginning and both Electricians have good reviews (I found both on homeadvisor.com). Both told me exactly what needed to be done without me saying anything and they both nailed all the code requirements, but man with both estimates being so far apart i don't know what to think.
Thoughts?
Old 05-07-2017, 05:52 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Thoughts?
Guy #2 is really busy and doesn't need the work.
Guy #1 just wants to do the job or wants to keep busy, although he sounds WAY too cheap to me.
I would have put it somewhere in the middle.
Old 05-07-2017, 07:53 PM   #7
Rewards Points: 194
Agreed. I had a guy once give me an estimate of $1,300. I thought that was high, but i guess that is a median price.
Old 05-08-2017, 12:31 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 3,666
$600 seems below-cost. Are the estimates for the same scope of work? Does the $600 estimate include detailed line items describing all the required work?
Speedy Petey likes this.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 05-08-2017, 01:06 PM   #9
Rewards Points: 194
Hey guys he said and I quote:
" it includes the labor and Materials and digging and putting the dirt back a complete job from the panel to where the receptacle is going for the filter. "
Old 05-08-2017, 03:41 PM   #10
THAT INCLUDED DIGGING AND BACKFILLING???
NO WAY a real electrician could come close to $600 for a job like this. He has to be retired or a side-jobber.
The Following User Says Thank You to Speedy Petey For This Useful Post:
mm11 (05-09-2017)
Old 05-08-2017, 04:13 PM   #11
Rewards Points: 194
Well he did come with his son and he had his son doing the run measurements and such and his son was about 18-22 (I am bad with ages) so maybe you're right.
Switching Thermostats from Line Voltage to 24V Units LifesABeach HVAC 3 01-22-2017 08:31 PM
Rusting Evaporator Coil: How long do you think, normality, and primary drain line professorj HVAC 1 11-29-2015 08:58 PM
installing refrigerator ice maker line xnera Plumbing 13 07-11-2013 07:11 PM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
