New 240V Receptacle Reads Zero Volts - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 07:41 AM   #31
Originally Posted by Code05 View Post
No revision needed, you are correct reguarding the grounding terminations on devices. See 250.126. Its gotta be green.
Thanks, good to know
Now just need the Mfg to know
Does the device serve a dual purpose?
Does it have the grounding symnol indication anywhere?
Old 09-19-2009, 08:11 AM   #32
I don't know if that was a rhetorical question, but it does not have a grounding symbol anywhere. There were no instructions on the package, either, nor are there any on the Cooper website.
I looked at the receptacle again last night. It's definitely a silver screw, but I can see where someone might think it was somehow a little green. But it's not at all like all the grounding screws I've seen elsewhere.
Madroaster is offline   Reply With Quote
Old 09-19-2009, 12:35 PM   #33
" Euro " electrician
frenchelectrican's Avatar
Ok to make it clear here is that siliver screw is on the yolk strap { metal strap to hold the recetaple } if so that is ground screw location not anywhere else at all ?
If that case the yolk and ground slot both must be use with ground wire you do not need the netural at all due you have straght 240 volt load.
I know you mention red and black conductor so that fine for hot conductor.
Merci,Marc
Running 220v Electronics on 120V Outlet? hellfire Electrical 42 01-14-2014 08:59 PM
Help with 20A 240v receptacle jayp Electrical 14 07-11-2011 06:21 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
