New 240v Plug Receptacle Not Powerring Devices, Pic Of How I Wired It - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2015, 02:26 PM   #16
Super Moderator
joed's Avatar
Rewards Points: 30,928
That breaker should work fine. You just need to move down one slot.
If you look at the breaker you have it has a gap between the contract points. That will fit over the black divider.
The Following 2 Users Say Thank You to joed For This Useful Post:
KevinEF7 (12-18-2015), Speedy Petey (12-20-2015)
Old 12-18-2015, 02:26 PM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 358
I believe this is the style breaker you need, it can only go in the top 2 middle positions.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 12-18-2015, 03:38 PM   #18
Food Truck & Old House
Rewards Points: 332
Do you happen to know a specific style/name for it? How come it can only go in the top middle positions? If I cant mount it on the bottom row, that means I will have to re-wire I believe, dont think I left enough slack to route to the top of the box. Rookie mistake 101
KevinEF7 is offline   Reply With Quote
Old 12-18-2015, 03:40 PM   #19
Rewards Points: 332
Sorry I missed this post, I will double check the breaker I have.
Old 12-18-2015, 04:22 PM   #20
Rewards Points: 48
No rewire. a short piece of 14 or 12 or what ever and a wire nut.
bernie963 is offline   Reply With Quote
Old 12-18-2015, 05:05 PM   #21
Rewards Points: 536
if the stabs on the breaker are vertical & not horizontal move it over a space , then you will have 240 volts. so you may have enough wire. i belive that is what they call a 1" double pole breker. or you can use what rjniles said.
circuitman is offline   Reply With Quote
Old 12-18-2015, 05:42 PM   #22
A "Handy Husband"
rjniles's Avatar
Rewards Points: 358
Look at the diagram, shows only 120 on the lower slots. There may be a lockout tab on the breaker.
Old 12-18-2015, 06:10 PM   #23
Master Electrician
Rewards Points: 5,262
The posted diagram shows two locations suitable for 240 volts.
brric is offline   Reply With Quote
Old 12-18-2015, 06:18 PM   #24
Super Moderator
joed's Avatar
That panel is an FPE, very common in Canada. You simply need to span any one of the black tabs with that breaker and 240 volts will be present.
It could go in 2/3, 4/5, 6/7 or 10/11 and work for 240 volts.
Old 12-18-2015, 06:22 PM   #25
A "Handy Husband"
rjniles's Avatar
Rewards Points: 358
Yep, looked again and see positions on the Lowe stabs.
Here is the breaker:
http://www.amazon.com/FEDERAL-PIONEE.../dp/B004FFXRU6
Old 12-18-2015, 07:35 PM   #26
Master Electrician
Not according to the buss diagram.
Old 12-19-2015, 12:44 PM   #27
Rewards Points: 332
Thank you gentlemen, I was infact able to simply move it to spot 6/7 and it gave 240v and the heater came on and life in the garage was once again livable, was a bit of a fight to get those 8 gauge wires to budge though. I appreciate all the expertise given as always. Merry christmas!!
The Following 2 Users Say Thank You to KevinEF7 For This Useful Post:
rjniles (12-19-2015), supers05 (12-19-2015)
Old 12-20-2015, 12:44 AM   #28
Electrician
Rewards Points: 12
The diagram is simply an example and not an indication of the only possible way to install breakers.
Jhellwig is offline   Reply With Quote
Old 12-20-2015, 08:32 AM   #29
Master Electrician
Baloney
Old 12-20-2015, 08:46 AM   #30
Licensed electrician
Rewards Points: 3,740
The diagram needs to accurately reflect where certain breaker types like a tandem can be installed. They are not generic.
I wired a 240v subpanel, and none of the outlets work.......... Help! :) wfsupply Electrical 44 12-16-2010 02:51 PM
hardwire a pre wired, plug in fluorescent fixture...? inlovewithohio Electrical 3 12-01-2010 11:10 AM
Two devices on a 240v circuit??? mopowers Electrical 3 10-09-2010 07:57 AM
30A 240v plug Red Squirrel Electrical 3 07-22-2009 12:48 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
