Neutral Jumper Between Back-to-back Switch Boxes? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 3 Post By CodeMatters
  • 1 Post By MTN REMODEL LLC
  • 2 Post By Nealtw
  • 2 Post By Sepp123
Old 05-30-2019, 12:09 PM   #1
Rewards Points: 16
Neutral jumper between back-to-back switch boxes?
What's the easiest but correct way of bringing a neutral conductor from a switch box to another switch box almost directly behind it on the other side of the wall? Both boxes are a type of old work box that could be removed without damaging the drywall, and both switches are on the same branch circuit. Just wondering if there's a more elegant solution than running a short length of 14/2 Romex and capping the black on both ends.
Sepp123 is offline   Reply With Quote
Old 05-30-2019, 12:42 PM   #2
Rewards Points: 320
Re: Neutral jumper between back-to-back switch boxes?
Are you needing a neutral for a new dimmer? Or have you lost the neutral to part of the circuit?
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Sepp123 (05-30-2019)
Old 05-30-2019, 12:47 PM   #3
Rewards Points: 16
It's for a new dimmer.
Old 05-30-2019, 01:16 PM   #4
Oso954's Avatar
Rewards Points: 1,900
Take that dimmer back to the store and get a “no neutral required” dimmer.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 05-30-2019, 01:16 PM   #5
Rewards Points: 3,438
You need to run the short length of 12-2 (14-2 for 15 am circuit) and use, not cap off, the black to supply hot to the subcircuit needing the neutral.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 05-30-2019, 01:27 PM   #6
retired framer
Rewards Points: 15,702
He needs a neutral at a switch leg what would he use the black for? He would have to pull the light and cap a black there.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Old 05-30-2019, 02:15 PM   #7
Very Stable Genius
CodeMatters's Avatar
Rewards Points: 7,994
Every cable is required to contain both supply and return such that
a clamp meter around the cable will always read zero. There are
exceptions that involve AL and/or fiber plates but they don't apply
here. Is it a rule I might cheat on in my own house....maybe...but
not if I could find a "no neutral req'd" dimmer as @Oso954 suggested.
CodeMatters is online now   Reply With Quote
The Following 3 Users Say Thank You to CodeMatters For This Useful Post:
MTN REMODEL LLC (05-30-2019), Nealtw (05-30-2019), Sepp123 (05-30-2019)
Old 05-30-2019, 02:42 PM   #8
Super Moderator
joed's Avatar
Rewards Points: 32,012
The first and most important thing is the BOTH switches need to be on the SAME breaker. You can't bring a neutral from another circuit from one box to another.
Old 05-30-2019, 04:01 PM   #9
retired framer
He said they were.
figure 7-14
Old 05-30-2019, 04:13 PM   #10
Rewards Points: 16
I can't return the dimmer, so would it be kosher to connect 14/2 Romex to both black and white wires in "box A," and then cap the black wire in "box B?" Could I also cut the ground wires all the way back to the cable jacket?
Old 05-30-2019, 04:14 PM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,882
Thanks Code..... Never knew that.....(never had the issue, but learned something new)
CodeMatters likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-30-2019, 04:21 PM   #12
retired framer
I really can't imagine anyone checking a wire that is 6" between two boxes. But rules are rules. So run the power there and change the wire at the light.
MTN REMODEL LLC and Sepp123 like this.
figure 7-14
Old 05-30-2019, 04:48 PM   #13
Super Moderator
joed's Avatar
Do not cut the grounds off. Connect all the grounds together in both boxes.
The Following User Says Thank You to joed For This Useful Post:
Old 05-30-2019, 04:50 PM   #14
Rewards Points: 320
If you can't return it, why not just buy another?
And why cut off the ground wires?
Old 05-30-2019, 11:25 PM   #15
Rewards Points: 16
I asked about cutting back the ground wire because it seemed superfluous to connect a ground jumper between two switches that are already grounded. But it's academic because I'm now convinced a non-neutral-needing dimmer switch is the way to go, all things considered.
daveb1 and Nealtw like this.
