DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Neighbor's AC dims my lights! (https://www.diychatroom.com/f18/neighbors-ac-dims-my-lights-45083/)
knharper 05-23-2009 11:37 AM
My lights dim slightly when my neighbor's rather large AC unit comes on. Should I be concerned about this?
PaliBob 05-23-2009 12:23 PM
I would complain to your local Power Company, that is to whoever bills you for Power. It is in your interest to keep the incoming line voltage as high as possible, that is ideally when there is a minimal voltage drop between the pole Transformer and your meter.
When there is a notable dip in your line voltage when the neighbor,s AC comes on then you may also have a not noticeable lower line voltage due to the neighbor's non-cyclical loads.
AndrewF 05-23-2009 01:27 PM
Yes, call your utility provider.
I'd also recommend you get a plug in volt meter and see what your current voltage is and what it is when his A/C unit cycles.
Yoyizit 05-23-2009 03:17 PM
If your neighbor pulls 20A or 200A you should see a drop on your 240v between 300 or 3000 mVac and 20 or 200 mVac, more likely the lower values.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
