Need Some Help Installing A Bathroom Vent Fan. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2015, 09:26 AM   #1
ZZZZZ's Avatar
Rewards Points: 2,540
Need some help installing a bathroom vent fan.
This is replacing a non-functioning fan already installed. It has no light, just a fan controlled by a standard wall switch.
The new one is more complicated than others I have installed. It has a 2-speed fan, a light and a night light. Here's the wiring diagram from the nearly useless instructions. It just says " connect the wires according to the diagram."
The colored wires coming out of the fan's wire box are all 16 gauge. Do I need to use 16 gauge wire to connect it to the new 4-piece switch? Can I instead maybe use several runs of 14 gauge wire (which I already have on hand) and make my own color coding for the connections?
Also, the 4-piece switch doesn't have a ground terminal. How do I handle that? The switch will be powered by standard 14/2 plus ground wire.
Any other tips or traps I might run into with this one?
Thanks.
ZZZZZ is online now   Reply With Quote
Old 01-09-2015, 10:41 AM   #2
Rewards Points: 370
Who makes the switch?
petey_c is offline   Reply With Quote
Old 01-09-2015, 11:17 AM   #3
ZZZZZ's Avatar
Chinese company "Clever Elephant." . (No info on this switch at their web site.)
The fan/light itself is mfg'd /sold by Tamco/Tamlite. It is not a cheap fan. The "list price" was $200, but I paid $55 at Habitat ReStore. Brand new in box.
Here's the switch
Can I use one roof vent for 2 bathroom exhausts fans? P550 General DIY Discussions 19 05-18-2014 09:41 PM
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
attach bathroom fan vent to dryer vent hohadcr HVAC 9 03-08-2010 05:58 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 12:36 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
