Need New Circuit For Microwave But Panel Full - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2017, 05:29 PM   #1
Always learning...
fetzer85's Avatar
Rewards Points: 262
Need new circuit for microwave but panel full
We moved into this house last year and are updating the kitchen. Existing microwave is smaller countertop model but new one is above range style. It will need its own circuit however as you can see the panel is full. Are there any special style breakers I could use to free up a spot on the panel? Thanks
Need new circuit for microwave but panel full-img_20171006_161636793_1507325243244.jpg
fetzer85 is offline   Reply With Quote
Old 10-06-2017, 05:35 PM   #2
CodeMatters's Avatar
Rewards Points: 7,360
Re: Need new circuit for microwave but panel full
Yes, there are square D breakers available which support 2 circuits
in a regular narrow space.
Even so, continuing to stuff things into that already full panel may
not be the best plan. Is there room nearby to easily add a sub-panel?
CodeMatters is online now   Reply With Quote
Old 10-06-2017, 05:39 PM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Yes there's room below the existing panel. Would you suggest sticking with square d? Any specific model you'd suggest?
Old 10-06-2017, 06:02 PM   #4
Rewards Points: 312
you can go with whatever 'brand' youd like...
KPDMinc is offline   Reply With Quote
Old 10-06-2017, 06:04 PM   #5
Licensed electrician
Rewards Points: 3,688
Not all panels are listed for use with tandems. You need to check the label.
If you stay with Square D QO you can use the old breakers in the new sub.
Old 10-06-2017, 06:13 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 30,132
I would stick with the same brand. No particular reason other than I personally don't like the idea of mixing brands.
Old 10-06-2017, 06:59 PM   #7
I'd stick with square D for the same reason as @joed .
I think their might also be another reason related to trip
times but I don't think that discussion is necessary here.
Before adding a sub-panel below the existing panel, check with
your local inspector. Up here they require residential panels
be mounted as high as possible to a max of 1.7m for the
highest breaker. However, it's one of the rules the inspectors
tend to be flexible on as long as there's a good reason and
they're informed ahead of time.
Extending Wiring Before Circuit Panel... Zeigh Electrical 3 03-02-2013 08:36 PM
Help trying to identify Main Panel circuit breaker Interlock solution Linos Electrical 9 05-16-2012 05:00 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 11:32 PM
120 v circuit from 230 volt panel mills372 Electrical 3 09-07-2009 12:13 PM
