Need More Than 200 AMP Residential Service - Electrical - DIY Chatroom Home Improvement Forum
Like Tree14Likes
Old 08-02-2019, 02:11 AM   #1
Rewards Points: 2
Need more than 200 AMP residential service
We are building a new house in Edmonton, Canada, and my builder has advised me the electrical load calculation is already at 192.5 amps, and that's without a couple electric deck heaters (2x25A) and an electric vehicle charger (40-60A) I was hoping to install. See the list below. The trench from the back lane is still exposed (service going to detached garage, then underground to the house).
I was advised the only solution is to go with 400amp service from our municipal electrical provider (Epcor), which requires a separate electrical/transformer "room", special permits and wiring, and the associated additional costs will be tens of thousands of dollars ($40,000).
Is there NO other way to supply more than 200 amps to a single dwelling home, and still pass an inspection? I know you can "add on" electrical items later (ex. outdoor patio heaters), after the house is built, without pulling a permit. However, if I have a fire, I don't want my insurance company saying insurance is void because something was done without a permit.
It seems silly that the municipal inspection code requires less than 200 amps with everything running at once. That would never happen in reality !
LOAD CALC:
Based on the square footage there is a basic house demand of 11000 watts = 46 amps
Steam shower load of 13000 watts = 54 amps
Air conditioning load assumed = 40 amps
Floor heat mat load assumed = 8 amps
Induction range load of 12000 watts with demand factor applied = 25 amps
Dryer 30 amps at %25 = 7.5 amps
Oven 6700 watts = 28 amps at %25 = 7 amps
Steam oven 20 amps at %25 = 5 amps
Total = 192.5 amps
ss_blake is offline   Reply With Quote
Old 08-02-2019, 06:21 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
Re: Need more than 200 AMP residential service
Originally Posted by ss_blake View Post
I was advised the only solution is to go with 400amp service...
How about building 25% less house?
Or eliminating 50% of the gee-gaws?
TarheelTerp is online now   Reply With Quote
Old 08-02-2019, 07:03 AM   #3
retired framer
Rewards Points: 4,424
How much of that could be changed to nat gas?
Run a separate meter to the garage??
Do not use flat bottom gables with scissor trusses.
Old 08-02-2019, 07:04 AM   #4
Rewards Points: 750
Exactly! Why in the H-E-double-hockey-sticks do you need a steam shower, steam oven, induction range, etc. And can't you use gas-fired appliances (dryer, range, water heater, etc.)? Use your electrical power for items you actually NEED and are not available as gas-fired. You'll be "shocked" at all the amperage you will save!
BluegrassGuy is offline   Reply With Quote
Old 08-02-2019, 07:13 AM   #5
Rewards Points: 40
I think my cataracts are getting worse each day. I cannot find in the OP where the owner stated his residence had a gas service to his home ?
Canada must have some stringent utility laws. I installed twin 150 amp breaker box services on homes wherever I found the need for 30 years in my state here in the USA, and the POCO did not blink an eye.
keep_hope_alive likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 08-02-2019, 08:53 AM   #6
Acoustics & Electrical
Rewards Points: 134
NEC lets you apply demand for sizing.
Connected load should never occur under normal conditions. Coincident loads vs. Non-coincident load should be considered - i.e. A/C and elec heat. Modern devices are so energy efficient now, receptacle loads have plummeted.
Start applying demand to the load calcs and you should get back in range.
And don't turn everything up to 11 simultaneously.
keep_hope_alive is offline   Reply With Quote
Old 08-02-2019, 08:57 AM   #7
Rewards Points: 134
I would assume gas is present since i didn't see an elec furnace or elec water heater (for house, not shower)..
Old 08-02-2019, 09:24 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,252
Too bad he is not under the NEC!
He is from Canada.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 08-02-2019, 09:37 AM   #9
Super Moderator
joed's Avatar
Rewards Points: 30,090
Who advised you? The builder or EPCOR. I have never heard of a transformer room for a residential property.
I was just looking at their 'customer connection guide' and services over 100 amp by special permission only. 200 amp is the standard home service now and you need special permission.
Old 08-02-2019, 10:10 AM   #10
Rewards Points: 812
In the US, you can get separate feeds so that you can have multiple panels. @HandyAndyInNC has 4 panels (200 or 400 amp each)
Can't you just get 2 150 amp panels? Or, have a sub-panel run to the garage? I can't believe they want you to get your own transformer, much less one inside your house.
From a former border neighbor
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 08-02-2019, 10:31 AM   #11
Deleted Member
Shadow99's Avatar
Rewards Points: 1,030
As others mentioned, if you have gas (or a large propane tank), use that wherever you can. You'll be saving on energy costs as well.
There are load shedding units that can bring the load down. ie, shut of the EV charger when the steam shower is on. Or only allow certain loads if below a certain amperage. Talk to your electrician about these.
Epcor probably has to install a new transformer, and upgrade wiring to accommodate the 400A. These costs are usually passed on to the customer.
Shadow99 is offline   Reply With Quote
Old 08-02-2019, 12:31 PM   #12
Rewards Points: 134
He is from Canada.
Doh! There aren't demand calcs in Canada?
Old 08-02-2019, 03:53 PM   #13
MarginallyQualified
Yeah, but they're all metric.
Old 08-02-2019, 05:57 PM   #14
Deleted Member
Shadow99's Avatar
Our metric Amps are bigger than your Amps
Load calc seems to be done already. Many loads shown are at 25%, and fixed loads need to be at 100%
One thing that is missed, is generally AC and any heating loads are considered separate. ie, you don't generally use the AC and heat at the same time, so you just count the higher of the 2. Might save the OP a few amps (metric Amps ! )
Given the sq ft load, I'm thinking this is around a 4500 sq ft home !
Old 08-02-2019, 06:39 PM   #15
CodeMatters's Avatar
Rewards Points: 7,348
My numbers (based on 8-200) suggest the home is between 5812 and
6781 sq ft. No surprise that a 400A service is required unless measures
are taken to reduce the load. Load shedding for the EV charger is a good
idea @Shadow99 .
Attempting to apply NEC rules is silly. For example, 6-102 restricts number
of services to one (with exceptions of course, but I doubt they apply).
@keep_hope_alive 's observation regarding a lack of heat loads (water and
otherwise) is a good one.
Shadow99 likes this.
CodeMatters is online now   Reply With Quote
