Need Help With LED Wiring! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2019, 03:26 AM   #1
Rewards Points: 8
Need help with LED wiring!
Hello people.
So I found this old LED lamp but it's not working anymore. I took out the LED board and I want to use it with any mobile recharger(adapter).
What do I do for this?
Need help with LED wiring!-spec.jpg   Need help with LED wiring!-led1.jpg   Need help with LED wiring!-led2.jpg
Titaniumshield is offline   Reply With Quote
Old 05-02-2019, 08:11 AM   #2
Rewards Points: 238
Re: Need help with LED wiring!
You would need to know more than you do. The power specifications assume you are using the power supply included with the light. To know what voltage needs to be fed to the LEDs you would have to know the output it was designed for.
If you don't care...you can try hooking up that board to 5V and see what happens. You likely won't hurt the board with that level but it may not be "right".
Sdiver2489 is offline   Reply With Quote
Thermostat Wiring Question shobuddy HVAC 13 12-23-2017 05:45 PM
Old Home Wiring (UPDATE) with pictures mbrando1994 Electrical 7 01-27-2016 05:59 PM
Old House Wiring Traycam Electrical 14 01-03-2015 09:31 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
