Need Help: How To Change Ceiling Light Fixture To Plug In - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 08:57 PM   #1
Need help: how to change ceiling light fixture to plug in
I have an older light fixture that has wiring coated with almost a clear plastic (ie. no black and white)... and it also has a plastic coated ground wire... can I make it into a plug-in? and what do I need/any tips?? I've done this kind of stuff before, but was unsure with the clear wires what to do to be safe.. Thank you!!
powla is offline   Reply With Quote
Old 07-27-2010, 06:03 AM   #2
Rewards Points: 2,800
For wiring with the two conductors in a single cord, the edge of the cord with a lenghhwise rib should be the neutral. Otherwise you need to use a continuity meter (or ohmmeter) to find out what wire is connected to the socket shells (this is the neutral).
With the plug prongs pointing at you and with the ground prong down, the neutral prong is to the right. For a 2 prong plug the larger prong is the neutral.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 07-27-2010, 09:33 PM   #3
Thank you so much! I'm heading to the hardware store tomorrow so I might have more questions ... but thank you so much for responding!
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
