Need Help On Fan / Light - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 02:52 PM   #1
Need Help on Fan / light
Need help on were the wires go
I rewired a room. I Had the old knob and tube. The new wire Feed / source. I ran to the Light / Fan with 12-2. then I ran 12-3 out to the wall switch. And 12-2 from the wall switch to the receptacles. I would like to keep the Fan and receptacles Hot at all times.
And control the Light with the wall switch. Iím Only using one wall switch.
the fan has a blue - black and white wire.
Thank you
kevin l is offline   Reply With Quote
Old 08-01-2010, 02:58 PM   #2
Electrician
Proby's Avatar
In the fan box you will splice the white from the 12-2 feed to the white of the 12-3 switch leg AND the white on the fan wiring.
You will splice the black wire from the 12-2 feed to the black wire of the 12-3 switch leg AND the black wire on the fan.
Finally, you will splice the red wire from the 12-3 switchleg to the blue wire on the fan.
At the switchbox you will splice the white wire from the 12-3 switchleg to the white wire going out to the receptacle.
You will splice the black wire from the 12-3 switchleg to the black wire going out to the receptacle AND to a short 8" piece of wire that will go to one screw on the switch.
The red wire from the 12-3 switchleg will connect to the other screw on the switch.
The receptacle will be a normal installation, white to silver screw, black to brass screw.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
kevin l (08-01-2010)
Old 08-01-2010, 06:15 PM   #3
Thank you it worked
Old 08-01-2010, 06:40 PM   #4
Electrician
Proby's Avatar
Great!
Old 08-02-2010, 12:27 PM   #5
I am having trouble following the original post as to where the cables in all cases originate.The reason I am having trouble with this is that the switched receptacle does not have a ground,
dick
delta force is offline   Reply With Quote
Old 08-02-2010, 04:01 PM   #6
Hi the switch and Recep have a ground that are used
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
