Need Help With A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 08:25 PM   #1
Need help with a ceiling fan
I am up grading a house I bought and the previous owner capped the elec. box in the living room and the best I can tell robbed the power to wire up 3 can lights above the fireplace. I plan to install a ceiling fan, but need help in wiring it. Can I rob power back to the box in the ceiling and then route power to the swith box in the wall that has a open slot for a switch? The can lights are on a dimmer slide switch, and a cap over the other hole in the box.
justdoinit is offline   Reply With Quote
Old 03-18-2011, 12:29 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
sounds like you need to trace some wires to know what you have exactly. Then we can talk methods, but in short yes we can do that.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-18-2011, 05:39 AM   #3
I knew that would b e the next step, just been putting off going back into the attic, but plan too this weekend.
Old 03-18-2011, 06:28 AM   #4
Learning by Doing
Leah Frances's Avatar
You don't have to rob them. The can lights know how to share :P
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
