Need Electrical Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2010, 05:03 PM   #1
need electrical help
Have a light fixture with 2 white wires and 1 black wire bundled together and 1 black and 1 white bundled together. Out of the wall is coming 1 black, 1 white and 1 ground. How do I hook this up?
pepperman is offline   Reply With Quote
Old 07-09-2010, 05:34 PM   #2
dSilanskas's Avatar
Color to color. Whites tie in with the white coming out of the wall. The blacks tie in with the black from the wall and the bare ground wire ties in with the bare or green wire if present.
dSilanskas is offline   Reply With Quote
Old 07-11-2010, 06:43 AM   #3
Weekend Warrior
As far as I know, every hard-wired fixture or device needs to be grounded. If there is no bare or green wire coming from the light fixture, look for a green screw somewhere on the fixture housing and connect the bare wire coming from the wall to it.
H2O Engr is offline   Reply With Quote
Old 07-11-2010, 08:52 AM   #4
If you have doubts about the wiring hook up one ea. of these
http://www.homedepot.ca/wcsstore/Hom...7.105401_4.jpg
at the light box and at the switch box.
With equal wattage incands., if each bulb glows dimly [running at 60 vac and 40% of rated power] the wiring is correct.
Old 07-11-2010, 08:57 AM   #5
dSilanskas's Avatar
How about a keyless or a pullchain
Old 07-11-2010, 09:25 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Something is weird. Please post a picture of this wiring in this fixture.
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
