Need Electrical Advise Please. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2013, 11:03 AM   #1
Hi all I am trying to replace my dimmer switch and I see this when I take off the plate. From the wall I have two white wires that are connected. A blue wire connected to the dimmer and 2 red wires from the wall and one from the other switch connected to the other dimmer wire.
On the new one I have two Black and a green. Can anyone help me with this. I have included pics. Thank you.
ajstich is offline   Reply With Quote
Old 11-29-2013, 12:09 PM   #2
Licensed electrician
Rewards Points: 3,662
Leave any wires not connected to the dimmer untouched. The blue looks like the switched hot. The other is the constant hot.
Old 11-29-2013, 12:17 PM   #3
OK where would I attach the green ground wire at?
Old 11-29-2013, 12:34 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 24,018
Connect the two blacks to the same two wires as the existing dimmer. The green is a ground. Connect it to any other green or bare wires in the box. The box is metal so it can be fastened to the box.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
