Need Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2015, 12:12 PM   #1
Rewards Points: 6
Question
Need advice
Can a 30 amp circuit support 2 of the below heaters? If so, how many of these type of heaters do you think this 30 amp circuit will support before blowing?
Lasko 6221
120v
60hz
1500 watts
Thank you for any help offered.
giga_art is offline   Reply With Quote
Old 03-07-2015, 12:54 PM   #2
Oso954's Avatar
Rewards Points: 1,250
You can NOT connect those heaters to a 30 amp circuit.
Oso954 is offline   Reply With Quote
Old 03-07-2015, 01:08 PM   #3
Rewards Points: 48
Why not?
mule98h is offline   Reply With Quote
Old 03-07-2015, 01:12 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
You CANNOT have 15 or 20A receptacles on a 30A circuit. I can cite the code if you like.
Why would you need them on one circuit?
Old 03-07-2015, 01:14 PM   #5
Rewards Points: 299
They appear to be regular 120 volt cord and plug heaters, meant for a 20 amp outlet max. Per code, you can't put a 20 amp outlet on a 30 amp circuit. A 30 amp outlet will not fit the plug on the heaters.
If you need to use two of them from the same outlet, run a MWBC. Otherwise, use 2 different circuits.
Ninja'd
Syberia is offline   Reply With Quote
Old 03-07-2015, 01:17 PM   #6
Rewards Points: 48
OP doesn't say he has that. 30A recps with proper wire(#10) or direct wire the heaters
Old 03-07-2015, 01:19 PM   #7
Rewards Points: 299
These are $20 space heaters from Walmart, according to the model number. They'll have a regular plug on them.
The Following 2 Users Say Thank You to Syberia For This Useful Post:
mule98h (03-07-2015), Speedy Petey (03-07-2015)
Old 03-07-2015, 06:33 PM   #8
Rewards Points: 6
Thank you all very much for your responses. See below for additional clarification.
We are going camping at a state park and the campsite has a 30 amp electrical plugin. I should have not said a 30 amp circuit. To clarify the question "Can you (without tripping the 30 amp breaker box) plug in 2 of these heaters to that 30 amp box?" The box does have a regular outlet to plug anything in to it but i am told it only allows 30 amps of power.
Old 03-07-2015, 09:04 PM   #9
Mad Scientist
Ugh, campsite electrical. You'll probably (hopefully) find that the campsite electrical box has a 30A trailer receptacle with a 30A breaker, and a standard 15A duplex receptacle on a separate 15A breaker. You can probably run one of those heaters, I wouldn't bet on running two of 'em.
McSteve is offline   Reply With Quote
Old 03-08-2015, 07:36 AM   #10
Rewards Points: 48
2x1500= 3000watts/120v=25 amps
Old 03-08-2015, 10:23 AM   #11
Rewards Points: 6
Thank you all for your replies. I think the final answer is that i should not use this 30 amp hookup for both heaters as this would probably pull more than 80% of the power and this is not recommended for long periods of use.
Old 03-08-2015, 10:39 AM   #12
Super Moderator
joed's Avatar
Rewards Points: 30,854
That is not the reason. The reason is because those heater have 15 amp plugs and are designed to be used on 15 amp circuits.
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 09:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 06:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
