Need To Add 240V Pwr.. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-03-2014, 05:32 PM   #31
dmxtothemax's Avatar
Rewards Points: 7,820
Originally Posted by golf12 View Post
how do I tell what size the panel is and the gauge of the wires?
Is there another way to tell if there's no lettering visible on the wires?.
Can you measure the diameter of the main supply cables ?
dmxtothemax is online now   Reply With Quote
Old 10-03-2014, 10:45 PM   #32
Rewards Points: 248
Originally Posted by Jump-start View Post
FWIW, homes with electric heat are generally calced at 10 watts per square foot. So an insulated home that's 450 square feet would need 4,500 watts, rounded up to 5000. 5000 watts divided by 240 is 20amps.
Don't forget to factor for continuous load.
240X20X.8=3840 watts
I think you can safely squeeze 2 of those 2000 watt units on this 20 amp circuit, but would it be sufficient? ?
If you were going to try for a 30 amp circuit:
240X30X.8=5760 watts
Jake. is offline   Reply With Quote
Old 10-04-2014, 10:25 AM   #33
Rewards Points: 1,832
Thanks, I know. Good point though for the OP.
When sizing electric heat circuits always load them 80% of the handle rating.
Jump-start is offline   Reply With Quote
240v outlet mmiller Electrical 30 04-03-2013 11:23 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
240v questions.... ITSANSS Electrical 16 05-11-2011 05:40 PM
Replacing 240V Wall Heater with 240V Base Board Heater jasoncw Electrical 7 11-26-2010 10:39 AM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
