Need 3-way Dimmer Help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2010, 04:26 PM   #1
need 3-way dimmer help
I installed a 3-way dimmer into an existing 3-way circuit. The dimmer feature works fine, but the 3-way circuit lo longer works like a 3-way circuit. I can no longer turn the lights on-off at either switch.
beerdog is offline   Reply With Quote
Old 04-24-2010, 05:20 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,990
You got the wrong wire on the common terminal.
Old 04-24-2010, 05:42 PM   #3
Is the hot wire supposed ot go to the common?
Old 04-24-2010, 06:15 PM   #4
works now.had everything backwards. thanks
The Wife said, "The lights are flickering." Dimmer on aluminum wiring Law911 Electrical 4 03-26-2010 11:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
